bug on texture UV Transform
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
augdalmo
Hi Aoktar,
I have encountered a bug when I have tried to rotate a texture, on diffuse field.
I had selected UV Transform and then as I have rotated the R.Z axis the T.X and T.Y fields automatically was changed from default 1 to 0. Also Gamma was changed form default 2,2 to 0,1!
Then I have tried to change the T.X and T.Y fields, and C4D freezed immediately!
CTRL ALT CANC to stop.
Plugin and Standalone v. 2.23.2 - C4D v.16 - win 8.1 64 bit
it's a bug on octane floatsliders. If you open sub sliders this can occurs. Not a bug else other.
augdalmo
but it caused a crash of C4D
augdalmo wrote:but it caused a crash of C4D
yes, possible. Don't make unfolded the sub controls.
augdalmo
Hi Aoktar,
I have installed now the rc 2 of 2.23.2 plugin, this bug occour also on this release, do not believe it is appropriate to temporarily remove this function until you find a solution? ;)
M
augdalmo wrote:Hi Aoktar,
M
i think that you got it wrong? Solution is to not open the sub controls by this way. Custom sliders can't work like this. Or use c4d's default sliders
Return to “Bug Reports”
