Hi there,
I got a mograph color shader insider a c4d colorizer (i'm limiting the random colors to a defined gradient) - That seems to work properly,
I'm putting this material inside a mix material - Then the mix material is applied to a cloner to get a "mixed-material-random-colored-clones".
Now - When i'm rendering to the live viewer sometimes the shader works and sometimes it doesn't (refreshes dependent)
& When i'm rendering to the picture viewer i can never get the shader to work. What am i missing here?
scene & screenshot attached.
mograph color shader inside a mix material issue(FIXED)
- clonerIssue.zip
- c4d file
- (125.4 KiB) Downloaded 203 times
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0
https://yambo.me
https://yambo.me
Of course, I've double checked it before i posted this.
Resend only updated objects / all scene data doesn't effect it. The color shader inside the mix material still not rendering to picture viewer.
https://yambo.me
https://yambo.me
Ok sorry. I may check wrong. Looking again.Yambo wrote:Of course, I've double checked it before i posted this.
Hi, found the problem. It was not evaluating the sub materials.
I can send you a fixed version if you want. Or you can put sub material's tag on left of mix material to over object as a work-around.
Yes!
Still i׳m not sure i got you - i׳m doing something wrong, i׳ll be happy to get a scene file please.
Thank you very much.
https://yambo.me
https://yambo.me
I mean to put a extra tag for material which has mograph colors.
- a1.jpg (8.97 KiB) Viewed 3649 times
I׳m sorry but your explanation is very poor.
I am not new to c4d and i can׳t understand you properly.
So if it possible to get a decent explanation / scene file i׳ll be thankful.
https://yambo.me
https://yambo.me
I'm going to publish a new release with fix. But check your PM for a test versionYambo wrote:I׳m sorry but your explanation is very poor.
- 1.rar
- (129.19 KiB) Downloaded 227 times
You the best - all good.
https://yambo.me
https://yambo.me
