Rotating Environment
Moderator: JimStar
p3taoctane
I attached an Ocatne Rotation Transformation node to an Octane Image texture for an HDRI Environment Node
I can only rotate in Z and not around Y
Anybody have any ideas?
TBFX
If you connect directly to the image texture transform then you can just connect a translate node and translate the texture in x, effectively sliding the texture around the sphere it automatically gets mapped to. If you want to use a rotation transform then plug a spherical projection into the image texture and connect the rotation transform node into the projection transform pin and that should work as expected.
T.
Win10 x64|i7-9750H 2.6 GHz|32 GB RAM | RTX2080 max Q 8GB
p3taoctane
Thanks mate
Perfect
Return to “Autodesk Maya”
