OctaneRender 2 for Nuke [STABLE]
LFedit
Thanks Paul,
Would love to see Octane in Fusion! Looks like you have some pretty amazing workflows going for Nuke with the Octane Plugin. Especially with the right infrastructure to use network rendering directly in a node based compositing flow. I'll keep watching the Nuke forum posts, very interested in getting Octane Render and node based compositing workflow established for live action/cgi compositing work.
Cheers,
Ryan
Win 10, Threadripper Pro, Dual 3090s
2.23.2.16
- Compiled with Octane 2.23.2
- Internal plugin changes to allow for a Linux version.
- Fixed crash when accessing Render Layers panel prior to the Octane scene being loaded
2.23.2.17
- Added OctaneRenderGeometry node, where you can specify an ORBX or OCS scene and plug into the OctaneRender node, and the OCS/ORBX scene will be added to Octane scene. Click Restart Render to reload any scene specified in the OctaneRenderGeoemtry node. OctaneRenderGeometry nodes are placed in the Octane scene as a separate graph, and edits to those graphs are NOT saved in the .nk file (ie. the OCS/ORBX scene contents will always replace any edits made in the plugin). See http://render.otoy.com/manuals/Nuke/?page_id=1261 for details.
- Octane log pops now only popup once until you open the Octane Log (ie. multiple Octane Log msgs will not result in multiple popups).
- Exporting a Nuke timeline to ocs is now done via a Write node (rather than WriteGeo). Plugin the OctaneRender node into the Write node and select "ocs" as the output format (select a save filename of either .ocs or .orbx). This means that animated camera setting (such as Focal Depth) get saved to the ocs file. See http://render.otoy.com/manuals/Nuke/?page_id=1195 for details.
- Fixed problem with the installer of the Nuke8 version of the plugin
* Pls delete the C:\Program Files\Common Files\NUKE\?.0\plugins\OctaneRender.bundle\OctaneRenderWriter.dll file from your system
2.23.2.18
- Fixed error related to the use of the new OctaneRenderGeometry node causing the render to either ignore the addition geometry, or restart the render continuously
- Added support for HDR Light Studio V5
- Added "Keep Environment" to the Kernel knobs
* Known Issue: Using Import Octane Scene will import the entire scene into the current Nuke scene, and therefore wipe any materials you have setup for Nuke 3d Geo. I will address this issue in a future release
2.23.2.19
- Changed name of OctaneReferenceGeometry node to OctaneReferenceGeometry to indicate that it is a reference to an existing OCS/ORBX file
- Added "Save" button the OctaneReferenceGeoemtry knobs to save the Graph back to the source ORBX/OCS file
- Added help text to the OctaneReferenceGeometry node
- The Graph node created by an OctaneReferenceGeometry node is now named according to the OCS/ORBX filename
- Added Start and Stop render buttons on the Viewer toolbar (available when the OctaneRender node has been selected)
* Pls delete the C:\Program Files\Common Files\NUKE\?.0\plugins\OctaneRender.bundle\OctaneRenderGeometry.dll file from your system
2.23.2.20
- Fixed minor issue when using the Export Scene option
- Fixed issue where Card UV's were incorrect
- If a Nuke Camera is plugged into the OctaneRender node, the Nuke Camera Focal Length, Horiz Aperture, Focal Distance a FStop will be used by the Octane camera. This assume the scene units are in meters. Turn OFF Octane AutoFocus in order to use the Nuke Focal Distance
JohnMesh
I would show interested in a nuke plugin for linux face, if there is any chance let me know...
I am working on it at the moment...Should be ready early next week.
I have release a Linux version of the plugin - pls see http://render.otoy.com/forum/viewtopic. ... 30#p237430 for details.
eyeonestudio
Version 2.23.2.20 / GTX Titan x 2 / Win 8.1
I Want "Hide License Key"
Some settings can not save? (ex: Device Setting, Default Kernel Setting....) :?
Some People Like "Octane Standalone UI"
But want "Octane node", Into Nuke Node-Graph (ex : Octane Light, Octane Glossy Material...)
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
Return to “Releases”
