the grass essentials
JimStar
Elonius wrote:Thank you Sara I will give this a try. ...
Elonius wrote:Hey Sara, I was still unable to get this to work. ...
I suspect the reason you haven't got any more help here from Saramary.
Just FYI, here is the quote from RFC1855 - simple Netiquette Guidelines:
If a user is using a nickname alias or pseudonym, respect that user's desire for anonymity. Even if you and that person are close friends, it is more courteous to use his nickname. Do not use that person's real name online without permission.
Moreover, that the real Saramary's name is not even close to "Sara". You can never know for sure the real name of the person behind the nickname, can you?..
planung-klein
simdal wrote:hi planung-klein ,
the object to be repeated is of scatter?
Hi simdal,
thank, but i have set the plane as "Scatter". (picture "render-panel-Scatter")
It work very fine if set scatter in render panel, only 1-2 min. to transfering :-), but when i use more object with other setting in Octane properties, dont work...
If set to "As is" in render panel, and Scatter to Plane Objekt in Octane properties, I waiting up to 10 min. only Transfering. (Picture "render panel Scatter")
best regards
Stefan
Scatter only work when setting "Scatter" in render panel
Scatter dont work with setting "As is" in render panel
simdal
hi planung-klein ,
try to help. the "grass" object (the dupli object in your particle system) must be a "mesh type" scatter. Not only the plane.
A. select all the mesh grass (grass_bahiagrass ?)
B. change mesh type from "global" to "scatter" (view attachment, operation 1 + 2)
C. select the plane and add particle system
Ciao, SimDal ;)
Win 10 64, 4xGTX780ti 8xTeslaK80, Octane, Blender, Archicad
planung-klein
Hi SimDal,
YOU ARE THE BEST :-)
I havent setting Scatter to the Gras-Mesh, fantastic work fine :D :D :D
best regards
Stefan
Return to “Blender”
