OctaneRender® for 3ds max® v2.23.2 - 1.7 [OBSOLETE]
RobSteady
Jim, can you please fix the viewport texture issue?
Only thing you have to do is keep the setting from the V-Ray file "show shaded material in viewport".
Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
Goldisart
agree and I fully support.
Viewport is a sore spot 3Dmaks to stay - although it would be great to make reflections in support of the real ==
RobSteady
Goldisart wrote:it would be great to make reflections in support of the real ==
This may sound fussy but can you please try to write a proper sentence? Or at least use google translate when you post something here?
I know, nit-picking...
Elvissuperstar007
need octane light double sided (vray light double sided)
lunarstudio
The Material Converter is taking an extremely long time. Could you please look into this?
JimStar
Guys, don't worry if I don't answer to every single report here - I take into account them all if they are reasonable. Sometimes I just have no time to chat here...;)
Elvissuperstar007
error 2.23.2
hall_2_91.rar
(5.34 MiB) Downloaded 235 times
gabrielefx
Elvissuperstar007 wrote:error 2.23.2
I already posted this error in the previous post...
Nobody here use these switches....
that's incredible....
DIO
Why isn´t it possible to use a negative value in the amount of the displacement? If I remember correctly this was possible once.
Is the only possibility for negative Displacement inverting the texture map?
corei7-4930k 6 x 4,0 Ghz, 32GB RAM, 2x 980 Ti
Win7 64bit, 3dsmax 2014 / 2015
JimStar
Dom74 wrote:Hi Jimstar,
It seems that D.O.F. is not respected in render passes in octane viewport.
You just need the "Distributed tracing" checkbox enabled in "Info passes setup" group of Octane settings. ;)
Return to “Releases”
