Hey,
I just updated earlier today. Unfortunately it seems that render layer masks still aren't quite working. IIt's definitely much better than the previous release, and there's no longer any noise as their was. It just seems that the mask is ever so slightly expanded from the object. I've attached an image demonstrating this (see the white pixels around the edge). Do you there might be a fix for this on the way?
Multi-passes don't line up [UPDATE: Still off on v2.22.2]
what are you trying to do exactly? And where do you do this?MoGrafik wrote:Hey,
it should be appeared so much. Try premultiply alpha in camera imager
can you post saved image and your scene?
Ahmet, I've attached a sample c4d file and the corresponding psd outputs. You will notice a thin white line around the box that should not be there. I hope to find a solution to this issue.
Thank you!
Thank you!
- Screen Shot 2015-05-14 at 12.22.29 AM.png (21.75 KiB) Viewed 6444 times
- octane_test.zip
- (1.9 MiB) Downloaded 302 times
See attached ae projectraincity wrote:Ahmet, I've attached a sample c4d file and the corresponding psd outputs. You will notice a thin white line around the box that should not be there. I hope to find a solution to this issue.
Thank you!
- octane_outline-prob.rar
- (2.81 MiB) Downloaded 313 times
So whats the fix?
Download my free Octane resources!
Paper Lantern | Fresh Snow (C4D Only) | Keyboard Displacement Texture | Solar Panel Texture
Mac Pro (2012) | 2x6Core 3.06GHz | 64GB | 1 x Titan Black 6GB
Portfolio: http://www.deltawavefx.com
