Multi-passes don't line up [UPDATE: Still off on v2.22.2]
MoGrafik
Hey,
I just updated earlier today. Unfortunately it seems that render layer masks still aren't quite working. IIt's definitely much better than the previous release, and there's no longer any noise as their was. It just seems that the mask is ever so slightly expanded from the object. I've attached an image demonstrating this (see the white pixels around the edge). Do you there might be a fix for this on the way?
Win 8.1 / i7 4930k / 2 x GTX Titan / Cinema 4d
raincity
I'm also having this issue with multi-passes not lining up perfectly. This is very important to me to get fixed.
Currently using v2.23.1 RC3.
My system: iMac 3.5GHz i7, GeForce GTX 780M 4GB
MoGrafik wrote:Hey,
what are you trying to do exactly? And where do you do this?
raincity
Here are a few photos that might help.
I'm trying to render out separate multi-passes that I can then composite into photoshop but they are not lining up perfectly.
it should be appeared so much. Try premultiply alpha in camera imager
raincity
Unfortunately checking premultiply alpha in camera imager did not solve the problem.
It looks like there is about a 1 pixel border around the alpha channel. I get perfectly clean alphas with the built-in physical render.
can you post saved image and your scene?
raincity
Ahmet, I've attached a sample c4d file and the corresponding psd outputs. You will notice a thin white line around the box that should not be there. I hope to find a solution to this issue.
Thank you!
Screen Shot 2015-05-14 at 12.22.29 AM.png (21.75 KiB) Viewed 6447 times
octane_test.zip
(1.9 MiB) Downloaded 302 times
raincity wrote:Ahmet, I've attached a sample c4d file and the corresponding psd outputs. You will notice a thin white line around the box that should not be there. I hope to find a solution to this issue.
Thank you!
See attached ae project
octane_outline-prob.rar
(2.81 MiB) Downloaded 313 times
dotcommer
So whats the fix?
Download my free Octane resources!
Paper Lantern | Fresh Snow (C4D Only) | Keyboard Displacement Texture | Solar Panel Texture
Mac Pro (2012) | 2x6Core 3.06GHz | 64GB | 1 x Titan Black 6GB
Portfolio: http://www.deltawavefx.com
