OctaneRender for Carrara 2.17.0068 [Stable]
Carrara (Integrated Plugin developed by Sighman)
Sighman
A new update has been posted to this thread for the 2.17 release to fix a crash bug when the scene is paused.
You do not need this version if you are using the 2.2x release...
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Spectralis
Sighman wrote:A new update has been posted to this thread for the 2.17 release to fix a crash bug when the scene is paused.
Wow! Thanks for the fast response. I'll stick with 2.21 for now but may go back to 2.17 if I run into any problems.
ASUS Maximus VI Extreme, i7 3770k, 32GB RAM, 4 x GTX760 4GB, Win 8.1 x64.
Veneris
Is there a problem to create animations with this plugin BETA? I have thought about buying it but I will not find surprises as the plugin for DAZ Studio. Does shader RedSpecSSS here in OC for Carrara? Characters from DAZ Studio work well with this plugin? Are there no problems with adjusting clothes? :?:
Intel Core i5-2500 CPU @ 3.30Ghz (Quad Core), 12.0GB RAM, NVIDIA GeForce GT 620. Windows 7 (64 bits)
Sighman
Veneris wrote:Is there a problem to create animations with this plugin BETA? I have thought about buying it but I will not find surprises as the plugin for DAZ Studio. Does shader RedSpecSSS here in OC for Carrara? Characters from DAZ Studio work well with this plugin? Are there no problems with adjusting clothes? :?:
Yes, animations work with the plugin.
No, RedSpecSSS is not supported.
Gen 4 works great. Genesis and Genesis II work but can use a lot of resources.
Clothing works via auto fit.
You really should play around with Carrara a bit before deciding to buy. There is a demo version of the plugin as well.
Return to “Carrara”
