Improved batch render script
stratified
Hi all,
I've spent some time combining the batch render script with the render animation script. This script will ship with the next release of the standalone. We already want to put it out here so you can already use it and help us find some bugs ;)
batch-rendering.lua
(36.71 KiB) Downloaded 774 times
thanks,
Thomas
smicha
Thank you!
simdal
Thank you! :)
Win 10 64, 4xGTX780ti 8xTeslaK80, Octane, Blender, Archicad
glimpse
Thanks Thomas!
smicha
Thomas,
When I am using this script (and this http://render.otoy.com/forum/viewtopic.php?f=73&t=41388) as the scripted graph node an error occurs. Is there a way to 'refresh' script settings without a need of reloading it? How shall a proper scripted graph node work?
Could you also help in further improvement of the script http://render.otoy.com/forum/viewtopic.php?f=73&t=41388. I have several remarks which I'd love to be coded. I'll post them there.
r-username
i use both scripts everyday, thanks for the update
i7 960 - W7x64 - 12 GB - 2x GTX 780ti
http://www.startsimple.com/ - http://www.gigavr.com/
kavorka
Just tried it out and got this error
stratified
kavorka wrote:Just tried it out and got this error
I guess you're not using the latest version of Octane? The script "remembers" some of it's settings as part of the project and that feature was introduced only recently. It should work with 2.23.1.
cheers,
Thomas
stratified
smicha wrote:Thomas,
You can't use the script as a scripted graph. The easiest way to use the script is put it in your scripts folder (configured via File -> Preferences -> Application tab). Reload your scripts (Script -> Reload Scripts). Now you should have an entry in Scripts called batch-rendering. In the next release of Octane, the script will be always in the menu.
To clarify, there are 2 types of Lua scripts in Octane. Regular scripts and scripts that can be used by a scripted graph. Scripts for a scripted graph require a specific code structure. Those 2 types of scripts aren't interchangeable.
Unfortunately I don't have time right now to help out with the script. We're heads down in 3.0 development.
cheers,
Thomas
kavorka
cheers,
Thomas
yep, I'm a couple versions back.
Return to “Lua Scripting”
