My shit of a render trying the SSS provided
ajr0717
Hey guys
I was trudging along and I wanted to use the suggested SSS shader on the forum.
Well here's what I got.
Looks like poop on a stick
What went wrong?
http://postimg.org/image/5nx35zgzl/][img]http://s16.postimg.org/5nx35zgzl/paul1.png
http://postimg.org/image/cm17bxf41/][img]http://s16.postimg.org/cm17bxf41/paul2.png
ajr0717
A difference I could not follow from the version of the tutorial to the newest version of poser..
What is Material Mix-> Second Material-> texture2 in Poser pro 2014? (Input texture power gamma invert uv transform projcetion border mode scale texture specular roughness index of refraction bump normal displacement opacity smooth rounded edges filmwidth)
Hi - there has been some renaming of pins since that tutorial was put together.
Material1 = First Material
Material2 =Second Material
= Scale texture.
Also, You Scatter and Absorption is 0/0/0, and should be mid-grey.
You can enable the SSS Render Pass to see the exact SSS effect you are getting to fine tune things.
And the RedSpec SSS shader is better than anything I've been able to get, so take a look at that.
ajr0717
Your representation was quite fantastic Paul. The guy sitting down with the back facing
TRRazor
Appreciate the love, Paul :D
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
Return to “Poser”
