Version 2.23.1 - RC4 (Updated on 07.05.15)
Hi everybody,
i'm glad to publish the version 2.23.1 RC3 which is based on Octane sdk 2.23.1.
This version has changes for some parameters which are unit aware. This can cause different results on material outputs. So please don't switch your version in middle of a project.
Changes for 2.23.1 RC4
- New parameter for geometry. Automatic mode will allow to make all objects as movable. Use this carefully for very high amount of objects. This parameter is for interactive mode. We need to use object tags for animation renderings.
- Smart optimisation for complex scenes. Better feedback and smart behaviour for editing the objects. This is for geometry->automatic option.
Geometry->Automatic
Geometry->Automatic
- Experimental support for BP3D painting
- Update from R16.038 to R16.050 (You'll probably need to update your C4D to 16.050)
- Fix for exposure changes after first frame while pass rendering. It was happened when camera imager is not activated on camera tag.
Changes for 2.23.1 RC3
- Fix for crash on delete operation in node graph
Changes for 2.23.1 RC2
- Fix for incorrect behaviour of modes(normal/float/alpha) in imagetextures
Changes for 2.23.1 RC1
- SDK 2.23.1: LINK: http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
- Color profile is correctly affecting now the C4D material colors, color shaders on C4D materials.
- Fix for material converter and c4d's standard material(srgb/linear color profiles).
- Fix for render instance updates and even for Xparticles generators when render instances are selected
- Unit support for some parameters like amount/offset on displacement, focal-depth, aperture, etc. no camera tag, rounded edges on materials.
- selection set support for images and movie file support on C4D bitmap
- Hsv/rgb mode for octane colorgui (uncompleted)
- Keep environment parameter is back
- Also having some fixes from SDK. They has been reported by some users.
Note about "new.c4d" or "default.c4d" usage. If you have this scene as startup which is done by old version. Please create new one with current version to avoid a warning window.
IMPORTANT INSTALL NOTES:
Due to the switch to CUDA 6.5 you will need a current graphics driver of version 344.x or higher. On Mac OSX you will need a CUDA driver of version 6.5 or higher (see http://www.nvidia.com/object/mac-driver-archive.html). The minimum supported version of Mac OS is 10.7.
Also matching version of Standalone 2.23.1 is highly recommended.
And remove all old plugin files before installing. Any version conflict or old drivers can cause crashes
Cuda driver for Macos: http://www.nvidia.com/object/macosx-cud ... river.html
BUG REPORTS
I'll be happy, if anyone can be specific with bug reports.
I need to know that plugin version/Os/HW, bugreport zip. Last operations before crashes.
Please post your reports in topic of version which is related.
Thanks for contributions
Best regards,
Ahmet Oktar
Download the 2.23.1 (RC4) Windows version (R13-R16)
http://render.otoy.com/customerdownload ... C4-win.zip
Download the 2.23.1 (RC4) MacOsX version (R13-R16)
http://render.otoy.com/customerdownload ... Macosx.zip
Demo scenes for 2.00
http://render.otoy.com/customerdownload ... amples.zip
Demo scenes for 1.50
Facebook page
https://www.facebook.com/octaneforcinema4d
Also a new commercial training set by InlifeThrill Designs
http://inlifethrill.com/trainings/octan ... cinema_4d/
Please don't forget to check this forum section for finding the fresh and very awesome tutorials and other infos
http://render.otoy.com/forum/viewforum.php?f=87
Vimeo group for tutorials
https://vimeo.com/groups/209276
Please Some new tutorials (Special thanks to Inlifethrill)
Render Settings & Optimization with Octane Render for Cinema 4D
[vimeo]http://www.vimeo.com/124066262[/vimeo]
Lighting Systems with Octane Render for Cinema 4D
[vimeo]http://www.vimeo.com/126014404[/vimeo]
Materials and Shader Setups with Octane Render for Cinema 4D / Part 1
[vimeo]http://www.vimeo.com/125392583[/vimeo]
Using the Mograph Color Shader with Octane Render for Cinema 4D
[vimeo]http://www.vimeo.com/126058811[/vimeo]
NET RENDER document: http://render.otoy.com/manuals/Standalo ... ge_id=1248
Supported features:
Displacement(activate with displacement checkbox in properties)
Hair rendering
Full motion blur for geometry and camera
Rounded edges
Opensubdiv
Render regions
Distributed rendering
Daylight+texture environment
Random color texture for instances
Render passes
rodross
"-Keep environment is back"
Awesome! I'll test this on my main machine right away, if all is well then update everyone else and the farm. Thanks Ahmet!
David_S
Hi Aoktar,
you are superfast once more. I was curious and installed the Mac Version, but it looks like this.
Also I got a crash.
best regards
D
_BugReport.zip
(19.74 KiB) Downloaded 405 times
albehany
because the res folder is empty and have no file :)
and thank you ahmet for your handwork
can you use the "res" folder from Windows version? I'll fix it asap
eightvfx
same problem with this new version.
problem.rar
(67.26 KiB) Downloaded 442 times
eightvfx wrote:same problem with this new version.
problem.rar
Can you try different variations of this scene? Maybe some straight geometry without arrays.
eightvfx
albehany wrote:because the res folder is empty and have no file :)
You're welcome. I have fixed the osx archive.
martincarlson
When I'm opening old scenes - all values in materials etc is changed to centimeters in some cases. Not good when opening old scenes.
Is this going to be fixed? Either with a script or in a new release?
All old scenes are f*cked up right now.
Do not delay reply me! [emoji844][emoji844][emoji48]
([emoji8] just kidding, i'm calm)
Martin Carlson, Visual and Audial Designer at Katzenwaffe Creative Studio | www.katzenwaffe.se | Soundcloud | Twitter
Intel Core i7-5930K / ASUS X99-E WS / 2 x EVGA GeForce GTX TITAN X 12GB / 32 GB RAM / Windows 10 / C4D R16 / Octane Standalone 3.03.3 / OctaneC4D 3.03.3-R1
Return to “Releases”
