xparticles motion blur
jagger
How??
intel i7 3770k // 2 x Evga Titan Superclocked 6gb Vram // 16gb RAM
http://www.octavioalonso.com
Here
XP-motionblur.zip
(86.26 KiB) Downloaded 548 times
Janmansilver
Hi, I can't seem to get x-particles motion blur to work in the newest stable release? Other objects blur fine.
Janmansilver wrote:Hi, I can't seem to get x-particles motion blur to work in the newest stable release? Other objects blur fine.
could you tested the attached scene?
ChrisVis
Hi aoktar,
I tested the attached scene with Xparticles 3 and motion blur works. EDIT: with C4D octane 2.22.2 test3.
However, the cam in your scene was not setup right, because I think you made it before you made some changes to the camera tag.
The good old shutter alignment was set to nothing, so I selected "before". Also there was set a timeshift of 25, set back to 0 and voila, motion blur is there.
Cya,
ChrisVis
be sure to have all interactive motion blurs ticked on (in the live viewers options menue).
C4D R15 - C4DOctane 4.0 | Win7 64 | NVIDIA 417.22 | EVGA GTX 980 Ti SC | EVGA GTX 780 Ti SC |EVGA GTX 780 Ti SC
i7 4930K 6x4.3GHz OC | 64GB | ASUS P9X79-E WS
+ Netstor Turbobox 250A | 2x EVGA GTX 780 Ti SC + 2 x Palit GTX780 Ti 3GB | all watercooled
ChrisVis wrote:Hi aoktar,
Cya,
ChrisVis
Right, but it's not a mistake. I see this problem on old scenes. Propably this is some broken m.blur attributes(time shift, etc..) between old-new versions. I'll investigate the reason.
Janmansilver
Hi yes I also tested the scene posted here - the particles simply disappear when activating motion blur in the Octane camera tag.
This is what happens when i open the file
This is the render when not touching any settings
I then turned on the tag, and the render goes dark / the particles disappear
Caching did not help
Tried switching between transform and point - still no particles
Update: Hi sorry didn't see that you've already responded, thanks for so quick support, I'm running X-Particles 2.5 - maybe this could be an issue? I will try the settings suggested above then and will let you now at once. :-)
Janmansilver
Hi just tested with the suggested settings, but no luck here with X-Particles 2.5 and OctaneRender version 2.16.
following setting are wrong
try:
time shift=0
align. = before
enable particle engine
Janmansilver
Hi :-) I tested with the exact same settings as suggested and still no particles. I've also tested with the latest beta (Octane-for-C4D-2.22.2-test3) and still no particles.
Maybe it's an issue with X-particles 2.5? I'm runnnings with a GTX 980.
