OctaneRender™ Standalone 2.22.2
useruser
abstrax wrote:
useruser wrote:hi everyone,
it seems that v 2.22.1 needs a lot more memory for geometry
i already posted that in the c4d-forum: (alembicfile included)
http://render.otoy.com/forum/viewtopic. ... 87#p228014
sorrry if this topic is already discussed here :)
Could you send us the scene please so we can have a look? Thank you.
hi abstrax,
you only need to import the alembicfile and start render (downloadlink for the alembicfile is in the original-thread) no lights, no textures, only geometry and you can see the different memory-usage between 2.21.1 and 2.22.1
btw. once again a nice update. thanks a lot octane-team! :)
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
abstrax
useruser wrote:hi abstrax,
Sorry missed the file. Thank you.
manalokos
Having trouble with more complex scenes with scatter nodes, and groups of objects.
Sometimes when I add a new object or refresh a mesh, the scene doesn't update.
Other times I replace an orbx in a scatter node, and textures get completelly mixed in other scatter nodes meshes.
ie. I have some palm trees. 3 species, 3 scatter nodes, I replace one of them with some flowers, suddenly one of the palmtrees becomes pink, because it is using the other mesh texture.
perro_abombao
Hi abstrax...I think the render animation script is not working well....repeat the same frame..
funk
abstrax wrote: [*] Improved Fresnel reflection for specular and glossy materials. Until now the code assumed that the light was always polarized perpendicular to the reflection plane, which is usually not true. As a consequence, the Fresnel reflections were too strong at medium viewing angles (see http://render.otoy.com/forum/viewtopic. ... 39#p227739).
It's nice to see this fixed in glossy materials! I did some tests a while ago and found that octane's fresnel was matching an S-polarized curve, while the other 3d applications I used match a non-polarized (averaged P and S) curve.
I have always adjusted the glossy material specular value down to compensate for the extra bright fresnel in octane, but I may not need to now.
Smooth material using the default IOR 1.3:
Rough material using the default IOR 1.3:
enricocerica
Dirt texture doesn't provide the same result with 2.17 and 2.22.1 (see attached images).
I added dirt texture on the pavement.
2.17
2.22.1
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
Elvissuperstar007
error
octane 2.22.1 150330 014758.log
(2.11 KiB) Downloaded 265 times
abstrax
Can't reproduce the problem here. When I open the Alembic file in Octane Standalone 2.22.1, the geometry takes about 1.7GB. The same amount as in 2.21.1.
useruser
ok,
so this seems to be plugin-related.thanks!
sethRichardson
I stated what was wrong back in September glad they finally decided to listen :).
http://render.otoy.com/forum/viewtopic. ... 71#p204671
