I tried it in different ways following some discussions in this forum and website developers, but my scenes are always empty! I do not know what else to do, really!
Please help me
The errors you are seeing are due to an invalid transformation matrix from RhinoGrow, and based on the error showing a zero as the first transformation value, a zero would only be present if the "grown" object instance had an X Scale of 0. So perhaps try to make sure the scale is > 0 and see if that works better.Anyway RhinoGrow keeps giving me problems with CSV
Hi sfuga - I had a quick double-check about the matrices - I am unable to re-create the issue using the default settings. Does your viewport produce something akin to the attached? Could you please email me a screenshot (similar to the attached) as well as the relevant files? (Rhino file with base and scatter geometry, plus .obj file for Octane, plus the .csv file that was generated). I'd be happy to have a look.sgufa wrote:I changed the X Scale value (>0) but the result was the same: always the same error and always zero as the first transformation value![]()
Anyway...not bad! It is true I'd like to also use RhinoGrow, due to its simplicity and directness, but I don't have much time so I think I will continue with Phantom Scatter for now.
Hi. Open the OctaneRender Viewport in Rhino, righclick the Settings tree "Export Scene to OCS". Open the exported scene in Octane Standalone, rightclick the Mesh and Save as ORBX. You can then use that ORBX as a proxy source in the OctaneRender for Rhino plugin.I would be very happy if someone was able to explain how to export a model as a .obj file without losing the connected octane materials
