AfterEffects Closed Beta Testers Wanted
Car and boxes which you see in sample video, they are directly tweaked in C4D and exported via orbx command. It's possible to export some scenes with full setup, but it's not appropiate for big scenes. Also AE plugin can be used on different layers with different objects/orbx scenes. So it's possible to combine different objects with different kernels. Even it's possible to use some compositions as texture over objects. But still have lacks and need more improvements.
"they are directly tweaked in C4D and exported via orbx command."
I think the "orbx" command is not in C4D demo plug, I guess it is a Stand alone feature.
"It's possible to export some scenes with full setup, but it's not appropriate for big scenes."
"..possible to export some scenes.." will try to look into limitations, without the "live Viewer' C4d "edit in Stand alone" feature, the learn curve tricky.
"Also AE plugin can be used on different layers with different objects/orbx scenes."
I guess I'll have to purchase when available.
"So it's possible to combine different objects with different kernels."
If the very useful lighting of Octane can be passed through, you will have a winner!
"But still have lacks and need more improvements."
The community that deals with "broadcast", I suspect, will be a good revenue generator for Otoy as After effects/Adobe has not improved much of late and Ae has a huge portion of Broadcast market-special effects.
Thanks for the replies, your hard work and best wishes for Octane to be the Go TO between Modeling UIs and Effects UIs.
AE user since v5.0 (not CS5!) who uses Octane daily with c4D and AE for final output. Very, very interested in alpha/beta testing this product! Happy to answer any questions you may have for me.
everyday work + blog: http://www.neondopemachine.com
2x Deca-Core Xeon E5-2660 v2 @ 2.2Ghz | 128GB RAM | Windows 7 Ultimate 64bit | 3x GTX 1080 + 3x GTX 780 6GB + 1x Titan Black 6 GB | Cinema4D r17
Hi All,
could you please send some more details about how/where you are using AE/3D? I'm very curious to see what/how are you doing in AE. Please send to me a PM which contains your web site or portfolio to show somethings.
Best regards,
Ahmet
Best regards,
Ahmet
Count me in!!
I do a lot of industrial animations for trade shows and sales. All my work involves heavy 3D (octane) with a lot of compositing in AE
Here is a link to the latest video I did for the client. https://vimeo.com/122666514
Let me know if you guys are interested! I would consider myself an expert in After Effects and proficient in Octane.
I am very interested in being a closed beta tester for the After Effects Plugin. Our team of 5 production artists utilize After Effects CC 2014 in our daily workflow to produce videos, animations, and stills for global companies like HP, Canon, Kodak, and many others. We have been using Octane in conjunction with Cinema 4D R16 for close to a year now and are anxious to deploy the Octane technology in After Effects. We would be honored to provide professional and helpful feedback during the beta testing process. Please contact me directly to discuss this further.
