reflections off
Sub forum for feature requests etc
Elvissuperstar007
hi encountered a problem
had to make a card falloff reflection
profbetis
These are correct reflections. If you want to turn the reflections on the walls off, adjust the wall material appropriately (Specular parameter down to 0.1 or 0.0). Alternatively adjusting the roughness will diffuse the reflections much more while maintaining the reflections of the general room.
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
Elvissuperstar007
profbetis wrote:These are correct reflections. If you want to turn the reflections on the walls off, adjust the wall material appropriately (Specular parameter down to 0.1 or 0.0). Alternatively adjusting the roughness will diffuse the reflections much more while maintaining the reflections of the general room.
on the idea of the customer's walls should reflect
but the extra reflection to the customer does not need
profbetis
Yes, however the customer is specifying physically incorrect output. This is not Octane's function. What feature are you imagining would satisfy the task?
Elvissuperstar007
profbetis wrote:Yes, however the customer is specifying physically incorrect output. This is not Octane's function. What feature are you imagining would satisfy the task?
director and producer is not interested in the laws of physics! (((
glimpse
but You, as visualizer should be interested in physics. In short, apply proper physical properties through material (lower reflection, increase roughness values)..& You'll get what You need.
if that doesn't help & You need technically & realistically impossible results : render out two frames & do blending using mask or.. go to biased engines where "all the magic is possible" using thousands of dials..-in other words choose Your tools accordingly - Octane Render is not a "cheat-box" =) unbiased engines will never have such flexibility as they are designed based on oppositely different principles.
P.S. & sorry (imho) there's no need such functionality for render engine - if You already fake this effect..- there's no need to clutter work-space with pseudo parameters..that 0.01% user are going to use.
sadece
Why dont you use multipass? You can control the reflection easily in PS.
http://www.sadece.com.tr
i7 990x // 12GB Ram // 2x Titan X + Titan + 780 // Octane for C4D // Win7 x64
Elvissuperstar007
sadece wrote:Why dont you use multipass? You can control the reflection easily in PS.
this animation))
http://www.youtube.com/watch?v=BrYnodNUmYk
Return to “User Requests”
