Scatter data generator for sketchup
Forums: Scatter data generator for sketchup
Postby manos » Sat Mar 14, 2015 7:48 am
manos Sat Mar 14, 2015 7:48 am
Hello, I there any one that remembers a plugin that exports scatter data from a componment ? I can't find it.
Can you shere the download link ?
Thanks.
CPU: INTEL i7 3.40 GHz/RAM: 8 GB/GPU: 2XGTX690/OS: WIN 7 64 BIT/SKETCHUP 2014/OCTANE for SU
manos
Re: Scatter data generator for sketchup
Postby Jorgensen » Sat Mar 14, 2015 4:14 pm
Jorgensen Sat Mar 14, 2015 4:14 pm
You might find some useful plugins in this thread
http://sketchucation.com/forums/viewtopic.php?f=323&t=40908
Jorgensen
Postby manos » Sat Mar 14, 2015 4:42 pm
manos Sat Mar 14, 2015 4:42 pm
Thanks, but i m looking for a plugin i used in su 2014. It makes a document file with some sort of cordinates of the componmets and you put that document file in the scatter node and connect it to a mesh. That way I could make many copies of tha same mesh with low memory usage....I don't remember the name of it. I remember I found it through this forum.
manos
Postby Seekerfinder » Sat Mar 14, 2015 5:53 pm
Seekerfinder Sat Mar 14, 2015 5:53 pm
Perhaps you're thinking of Phantom Scatter?
Seeker
Seekerfinder
Postby manos » Sat Mar 14, 2015 6:33 pm
manos Sat Mar 14, 2015 6:33 pm
No i have phantom scatter.... It's not so sophisticated it's just a small plugin that was free.
This is how it worked :
You export the mesh to standallone OC.
Then you make a simple plane or a cube or something that works like a proxy and make it a componmet and define the axis. Next you place copies of the componmet where ever you like (or need). When you have finished with the placement of the "proxies", you select again the original first componment and run the plugin... It seams that nothing happens but its creating a document file with information for the position of this proxies.
This file you can use it with a scatter node and connect it with the mesh you had in the beginning.
I know you can still do this with placement but this plugin help a lot.
manos
Postby resmas » Sun Mar 15, 2015 4:22 pm
resmas Sun Mar 15, 2015 4:22 pm
Here you have mate.
I think you are looking for this.
viewtopic.php?f=31&t=28211&p=123487&hilit=scatter+data#p123487
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
resmas
Postby manos » Thu Mar 19, 2015 1:00 am
manos Thu Mar 19, 2015 1:00 am
manos
Return to SketchUp
Thu Jan 28, 2021 1:04 pm [ UTC ]
