hi
i wonder if it's possible to create a floor that consist of e.g. tiles, and they all get random textures applied?
i have created a floor using floorgenerator by cg-source (https://cg-source.com/floorgenerator.php), and tried to add random material ids by using his "Unique Material ID" script, but then i get lost.
i would like to use the "MultiTexture Map" plugin, by the same author, but i can't figure out how to start the plugin, and in the description is octane not supported.
does anyone know how to create more 'random' look floors?
creating an 'random' floor
just remembered only recently I found out the materialbyelement default 3ds max modifier
- in max 2015
- add the modifier, it will define random matID and create a multi/sub with different textures..
- didn't try it yet for floors, also looking for quick solutions since all the scripts and plugins look very messy - this seems doable..
http://knowledge.autodesk.com/support/3 ... D-htm.html
- last time I did a good wooden floor, I took a hand scanner scanned the wooden tiles, and cut and pasted all inside photoshop
, looked pretty great, huge map though.. the oldschool way
3dmax, zbrush, UE
//Behance profile //BOONAR
hi acc24ex
i just found out that the floor generator script automatic creates different material ids - so after creating a floor you can add a multi/sub material and it's all fine
hi acc24ex
thanks for your tips - it works just fine
thanks
thanks
