OctaneRender™ Standalone 2.21.1
gardeler
rendertimes and motionblur
I have done a few projects in octane now, the latest with v 2.20. when checking render times, there is a rather violent time increase in some of the frames with motion blur. It behaves similar to vray, and other ray tracer render engines. But when I did projects with motion blur in the past, there were hardly any increase in render time, only a little more noise in the "blurry" places.
I hope this is a bug? Or should we expect longer render times on frames with motion blur on them? (the latest project went from 4 mins a frame to 45!! :o
I was running on multiple configs with 4 x titans and some 2 x titanZ on linux.
coilbook
gardeler wrote:rendertimes and motionblur
same here. Otoy please check it for a bug. I noticed before with and without motion blur almost no difference in render time. Now more motion blur duration i add longer render time. I did a test for a moving car: no mb 50 samples per second, mb on and if camera is looking at the front of the car 30 samples per second, and mb on and it shows a side of a car passing left to right where you see more car blurriness it drops to just 10. In 2.1x there was not much speed drop
abstrax
If you send us a scene that has no or only a small slow down in 2.1 and a big slow down in 2.2, we can investigate.
gardeler
[/quote]
If you send us a scene that has no or only a small slow down in 2.1 and a big slow down in 2.2, we can investigate.[/quote]
The slowdown I experience is from before 2.0, where I had camera fly-through's with large amounts of motion blur with almost no render hit at all. I know that object motion blur and camera motion blur is different, but the render hit now pretty much kills octane's biggest advantage; speed. during another project, we did a head to head with vray on a shark jumping out of water. Octane was faster until we came to a frame where there were too much motionblur and vray rendered at the same speed here. (the octane machine with 4 x titans also costs around 4 times as much) So that project were not a good idea to do in octane because of the motion blur issue.
I will prepare a file for you, but I also noticed something else. On the frame that has motionblur, there is one core on CPU that is going up on 100%. Looks like the linux window manager process. On a frame with no motion blur, the CPU is not going up. Is that normal? The whole system slows down and gets sluggish on that frame. I also tried it on my windows box. I don't have the cpu hit here, but it also gets more sluggish and "studdering" in the interface on a frame with motion blur.
Anyways, hope there is something that can be done to improve this. I'm lucky that I have access to a large amount of render power, but for somebody that has a small setup, a render time increase from 5 min to 73 min could shatter any deadline in production...
I will try to get you that file asap.
M
gardeler
I have sent you a PM with a package link.
coilbook
here is my example what happens if objects moves a bit faster creating more motion blur render time doubled. Truck was cropped in the second picture but both frames have same size truck and environment
abstrax
I had a look at your scene and the slow down was in 2.06, 2.17 and 2.21.1. I didn't have much time to look into it, but there is probably some issue with the Alembic files: When you look at the compilation time at frame 220 (which still renders fast), the compilation takes only a couple seconds. At frame 230 (which renders slow) the compilation time takes almost a minute. So something is very wonky here.
Did you manually export the Alembic files? Which tool did you use and from which 3D application? On Monday I will have a closer look at what's actually happening. (Interestingly the mesh and triangle count stays the same.)
Cheers,
Marcus
gardeler
[/quote]
Cheers,
Marcus[/quote]
Hi Marcus
Thank you for looking into the issue. Yes there seems to be something funky going on. I used "crate" in maya to get the alembics out. I always use crate as autodesk's alembic solution does not support shader assignments. (as far as I know)
Let me know if you need me to do any other test's or alembic outputs for you.
Martin
abstrax
gardeler wrote:Hi Marcus
Martin
Could you post the Alembic export settings you were using? I don't know crate, but maybe I can spot something obvious.
gardeler
Martin
I usually use the default settings + the "global" check box. That works the best for me.
cheers
