Hello everybody,
i have 2 little problems...
I'm doing an animation of some solar panel and i need to reduce the visibility of the reflection of the sun on th epanels.
Despite i reduce the sun size value (or even negative) the sun reflection remain unchanged and is too big.
Do you know how to reduce it or is there a way to don't have a sun visiblity but still have the light coming (like a distant light)?
Another question: I'have seen that there is no environmental fog options..how do you do it? Do I need to export a depth buffer?
thanks
sun visibility and fog
I am not sure how to fix your sun problem, there are not visibility options for the daylight sun. Perhaps you could play with the "Turbidity" parameter in the daylight node, or with the "Highlight compression" in the imager.
Yes, currently you need to export the Z pass and add the fog effect in post.
Here is an image to understand the problem..the sun reflection is very big..
there is no way to make it smaller...
I tried turbidity but I loose the correct illumination..
Will try the other feature..
Highlight compression reduces it a bit but i loose other kind aspects of the material...
Is this an Octane core provblem or just a little feature missing?
thanks
thanks
Thanks Juanjo,
I knew that but i need the material a bit blurred as reflection...
thanks anyhow..
thanks anyhow..
