OctaneRender™ for Blender 2.21.1 - 7.6 Win [OBSOLETE]
JimStar
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Fixed the filenames encoding inconsistency between Blender and server in some cases.
  • Fixed the 2D-transform node translation bug.
  • Minor fixes and improvements...
Blender Octane Edition - 7.6 (2.73 (59.1MB autoinstaller file)
Octane Server - 2.21.1 - 7.6 (10.5MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.21.1 - 7.6 (9.0MB autoinstaller file)
MattRM
Matt
Garquitectos
Many thanks!
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
voon
I still have the old problem, that Octane Server is not releasing the GPUs after a render ... it keeps them at 50% power when rendering is finished instead of dropping down back to idle.
I made a screenshot in MSI Afterburner to explain:
1. You can see that the GPU power of the GPUs is in the beginning around 10%. That is with Octane Renderserver running, but after a freesh start, i.e. it has not done any rendering so far, but I can acces the Live DB etc in Blender.
2. Tallest Peak. This is Octane Server rendering my small demo picture of just a cube. You also see that in the tall "GPU Auslastung" (usage) peaks at that moment.
3. Long high plateau in the middle. This is after the rendering. It does finish the job (2000 of 2000 samples), but it never drops back to 10% .. it keeps the GPUs around 50% power usage.
4. Drop at then end. This is me closing and restarting the Render Server. it is then back to 10% ... until you render soemthing again...
vipvip
i'm new in Octane for blender ( but i use Octane and octane for Lightwave for a long time), so sorry if some of my posts have already be asked.
Globaly, i find this plugin version fine but i encounter a problem:
*When i render an animation, it works
*after this , if i enable " motion blur internal" and render again the animation ,it doesn't start to render
*so i uncheck 'Motion blur option" and launch 'render animation' again: it seems to render, very quick, but if fact, the rendered frames are black...
There is apparently troubles with internal MB, can you confirm it ?
Is there a workaround or special case to use it correctly ?
Thanks in advance
billkeane
voon wrote:I still have the old problem, that Octane Server is not releasing the GPUs after a render ... it keeps them at 50% power when rendering is finished instead of dropping down back to idle.
I wonder if this is a Blender issue? I noticed that Cycles does the same thing:
http://blenderartists.org/forum/showthr ... -rendering
JimStar
Next version HERE.
Return to “Blender”
