I need help for octane C4d Demo .
huyrua811
i made this scene and render view but it so delay when my pc working
im use Path tracing just with 1000 sample . Why it so hard , my pc is very delay , so slow
This is my pc
Chip: Xeon e3-1231v3
Ram 16GB
VGA : GTX690
SSD:128 GB
Main:ASRock Fatal1ty H97
GTX 690 is not good for octane render ?
pls help :((
activate render priority in Settings->Gpu tab. Click gpu checkbox and select low or middle.
But i think your render is going very slow. 0.1ms/sec is very very low. Try to decrease diffuse depth, etc... This scene is from our comparison for Corona, can't remember our speeds. But i draw the directions in image, these will give more speed for you.
huyrua811
aoktar wrote:activate render priority in Settings->Gpu tab. Click gpu checkbox and select low or middle.
tks so much aoktar . It is better . But it still delay 5-8s :( i Cant work High Qualityw with GTX 690 ? i should update driver ?
can you test your cards with octane benchmark? Still very low speeds which i see here. Also interestingly your gpu's usage %25. I think low priority is decreasing this. Even in your first image i see free ram ZERO and one GPU is not rendering due out-of-memory. Additionaly GI_CLAMP<1 is clamping the ray and causes the break illuminations. Coherent ratio=1 is not giving accurate results also. These are just some note for you.
As i say, pls test and compare your cards with other's test results. 690 is not a weak card as i know, i should be close to a standard 780.
huyrua811
tks so much aoktar , i will update new driver and try test octane benchmark ;)
huyrua811
i test octanebenmark and get 35-40ms/s but with my scene c4d it still 0.5 ---> 0.7ms :| maybe my gtx 690 have problems
huyrua811
in the second scene, i deleted some unneccessary objects but nothing better. i don't know it's my VGA card problem or Octane setting problem ? who can help with another single VGA ? :|
16k sample , 0.3-0.6ms/s , time render complete 4hours :| scene file https://www.mediafire.com/?b885a34e0t2iehd
huyrua811
help me pls :(
huyrua811 wrote:help me pls :(
Edited a little bit the scene to make it faster. There is some changes on kernel settings, also on a few objects and their materials. Coherent ratio, gi_clamp and diffuse depth is most helpers.
I'll put the new scene. See my render info, speed and settings in pictures. I hope that helps.
New scene:
http://we.tl/gMtdTqADdy
huyrua811
yaaaaaaaaaaaaaaaaaaaaaaaa , i cant believe . It so amazing , very fast and really small delay . I get it , i loveeeeeeeeeeeeeeee youuuuuuuuuuuuu aokra :lol: :lol: :lol: tks so much , im so happy :mrgreen: :mrgreen: :mrgreen:
