Flickering in Animation
martinzip
Hey eyeonestudio
yes there are two surface really close to each other, the liquid in the bottle and the bottle surface are next to each other ...
Indeed I had coherent modus working ... so next try ... for the glas material ...
thanks for your help
martinzip
i think, you need at least 1000 maxsamples. Tweak it in live viewer, until noises disappear.
martinzip
I am working with 1500 samples
In the reflection there is a lot of noise, which I cannot eliminate with ae.
Next step?
Martin
FlascheTestGlas.mp4
(2.48 MiB) Downloaded 7002 times
Next step check my test scene. It's very well with some tweaks on kernel and material. Notify i have to use "coherent ratio" + "static noise" to decrease the noises. It's ok with 256-512 samples on DL or PT. Btw, not a good idea to try the removing the noises in ae.
test.zip
(1.76 MiB) Downloaded 413 times
martinzip
Ray epsilon changes a lot, the noise disappears in the reflections of the hydra image, the bottle looks completely different but no noise at all ray epsilon 0,011 ...
Are there any rules/thresholds/Frontiers for epsilons values
I will try with the liquid in and let you know ...
Martin
martinzip wrote:Ray epsilon changes a lot, the noise disappears in the reflections of the hydra image, the bottle looks completely different but no noise at all ray epsilon 0,011 ...
Martin
What's your bottle's dimensions? If your objects are small and scene is not big as a 1km. or more, try lower values. For big ranges of scenes, you may need to increase it. That's a treshold factor for lowest values of ray intersections. Because Octane uses floating point math and this is a limit on ranges of dimensions. Think that as a scaling correction factor.
miohn
hmmmm, asked the same before, but got no answer to my question.
(Are there some generell tips for settings/values for the "rayepsilon"?)
Mike
martinzip
Hey aoktar
the bottle is 40 cm, real world size...
I think the problem is a backlight situation, I tried a sphere behind the bottle and produces a lot of noise ...I will try in your demo scene with a backlight and your settings ..
martin
