Why can't I import "Images As Planes"?
justavisitor
I just moved a Blender Cycles-project from my Mac to my Octane Render-PC, and now I can't render an image that I previously imported as 'Image as Plane'.
The image shows just fine in Material view, but doesn't render. (I used Octane Image Tex.)
So I tried to import the image again, but the "Images As Planes" function doesn't work...
What am I missing?
Latest OctaneRender for Blender. Windows 10, i7 quad 3.7GHz, 16GB, 2xTitan.
JimStar
More detailed info is needed to understand what's wrong in your scene...
Steps to reproduce?.. Perhaps some screenshots?..
justavisitor
Well, the steps are really simple: :)
1) Start Blender
2) Shift+a/Images As Planes
3) Find/Open image
4) Nothing happens; i.e no planes and/or images are imported...
JimStar
justavisitor wrote:Well, the steps are really simple: :)
1) Start Blender
3) Find/Open image
I've just checked. What you describe - is the addon script which imports the images as planes. This script just knows nothing about Octane materials. It works for "Blender Render" or "Cycles Render" mode, but it knows nothing about Octane nodes.
You could ask the script developer to improve it, or just improve it yourself - it is open-sourced. ;)
justavisitor
Thank you. So there's no way to just add an image or a video to a plane?
justavisitor
Here's what I do -- could somebody please tell me what I'm doing wrong?
1) I have the default cube.
2) Add an Octane Image Tex
3) Open a .png image and Assign it
4) Open the .png in the UV editor
5) In Edit view w/ cube selected, go into UV-unwrap/Cube projection
6) The .png is now unwrapped on the cube - and it is visible in Material view.
7) In Rendered view however, the cube is rendered without the .png: Just the default cube in the default blue Octane sky.
So I'm obviously missing one or more steps somewhere along the way...
mib2berlin
Hi, you have to add a Octane material and image texture node too.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
justavisitor
mib2berlin wrote:Hi, you have to add a Octane material and image texture node too.
Cheers, mib
Hi, thank you!
May I ask in which order the nodes should be connected? I should have an Image Texture, an Octane Mix Material (for instance) and a Material Output, isn't that right?
mib2berlin
Hi, simplest textured mat is:
Cheers, mib
EDIT: Sorry for second display screeny. :)
justavisitor
mib2berlin wrote:Hi, simplest textured mat is:
Cheers, mib
Thank you very much for your time!
It's weird, everything looks the same here - except for the render (and the second screen :)).
Return to “Blender”
