Version 2.21.1
Ron
Hi Ahmet,
you mentioned changes to the node editor in this version (2.21.1).
What exactly was changed? I still get crashes while using it.
What time do you expect to get to a stable version of the node editor?
Thanks and regards
Ron
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Ron wrote:Hi Ahmet,
Thanks and regards
Ron
where is it crashing and what kind of? Do you have bug report? It should be much better atm, at least for me. I have completely changed the texture storage system. In last recent versions, that was causing the crashes.
Silverwing
+1 for Motion Blur in Render Layer Mask.
I am working on an commercial animation right now and it would really help me ;-)
Thanks in advance!
WIN 10 PRO 64 | ASUS X99-E WS | 3 X GTX 1080Ti | i7 5960X 8X 3,33GHz | 64GB RAM
Hi people,
here a bunch of new tutorials for passes.
related topic:
http://render.otoy.com/forum/viewtopic.php?f=87&t=44922
[vimeo]http://www.vimeo.com/119838883[/vimeo]
Ron
aoktar wrote:
Ron wrote:Hi Ahmet,
Thanks and regards
Ron
Don't have a bug report this time but will send one next time. I created a new material inside the NE in a new scene without any other materials.
Ron
miohn
again please,
Alpha not working in materials anymore.
Same project - b/w tex in opacity-slot worked fine before.
Now, when rendering, alpha gets not stamped out but renders black.
Has something changed here?
Do I need to use the render method 1 (send all scenedata) maybe for that to work?
As said, it worked before.
btw. where is the upload picture option gone?
regards
Mike
miohn wrote:again please,
regards
Mike
No, are you select enable alpha in kernels?
miohn
Hi Ahmet,
yes, alpha is enabled in Kernel!
Could I elsewhere by mistake checked or unchecked something
which prevents alpha in opactity-slot to be rendered correctly?
As already mentioned, in Material preview it looks o.k.
Mike
miohn wrote:Hi Ahmet,
Mike
i can say that all is working as usual. I don't know that's your issue. Try to build a simple test scene from scratch to check it.
martinzip
Hello
is the 2.21.1 stable for a production??
kind regards
martin
Return to “Releases”
