OctaneRender™ for Blender 2.21.1 - 7.3 Linux [OBSOLETE]
JimStar
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Added the workaround for 2.21.1 engine passes bug (sometimes passes rendering never ended). Now Blender will exit early in this case, so passes SPP value in some cases might be smaller than is set in settings. Will be fixed in next engine version.
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v7.3 Linux (96.3MB autoinstaller file)
mac3d
Hello Jim,the problem does not change, the same error..
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7f707cfdbca0)
Tried to access null node
Unknown pin ID 246
My system is Ubuntu 14.10 64bit..
My Computer:i7 2,6ghz ram 8gb schede video nvidia 9600tso 512mb gtx560ti 1gb mainboard asus p6t se sistema operativo:Ubuntu 14.10 64 bit
JimStar
I need more info...
Is it on any scene, even on default cube?
Is it from this installer or Blender is compiled by yourself from git?..
Synthercat
Hello there JimStar
I got 3 bugs to report
1. I had mentioned this before, it must have been overlooked. Alpha image texture does not seem to work for bump. Only Image texture does. This cube is bumpy but when I connect the Alpha image texture node to the bump (it was the exact same jpg to it), the bump disappears and the cube becomes smooth again
2. I've been reading about the SSS mat and how to use it. I've tried it and although I made it work, some settings seem to not function. When I copied my scene to Octane Standalone I realised they do work there. I am talking about the Absorption & Scatter colours... in Blender they behave as set to 0 for both. You can see the comparison of the pic in bug 2 and bug 3. I got the same settings, they should produce the same result
Here is my Blender file :
SSS.blend
(495.08 KiB) Downloaded 226 times
Also the scatter direction set to -1 should make the transmission colour disappear because I got the view-port on the opposite side of the lamp. The direction does not seem to affect anything in Blender and neither on Standalone too
3. Standalone Octane 2.17 64bit linux
(I post this here cause it has to do with image comparison of bug 2)
As you can see I got both absorption and scatter colours set to 0.5 RGB... but when I click on the colour to open up the colour picker they read as 0.7297401 RGB inside it, setting 0.5 there, make the node inspector turn to 0.2176376. Is that normal? Does it have to do with linear correction or something?
Thank you again for your work JimStar.
Having Octane within Blender is really amazing for us!
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
Synthercat
Can anyone replicate these?
mac3d
Hello Jim,yes is it from this installer and Is it on any scene, even on default cube
Octane: WARNING: only node-materials are supported: material "Material"
Octane: WARNING: only node-textures are supported: texture "Tex"
Octane: ERROR loading mesh. Server response:
Tried to access pin via an invalid ID P_RENDER_PASS_POST_PROCESSING (155)
Tried to access null node pin
Node type 86 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7f709555bca0)
Tried to access pin via an invalid ID P_FOCAL_DEPTH (49)
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7f709555bca0)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7f709555bca0)
Unknown pin ID 253
Tried to access pin via an invalid ID (253)
Unknown pin ID 253
Unknown pin ID 246
Tried to access pin via an invalid ID (246)
Unknown pin ID 246
Tried to access pin via an invalid ID P_MIN (107)
Tried to access pin via an invalid ID P_AO_DISTANCE (7)
Tried to access pin via an invalid ID P_RENDER_PASS_EMIT (143)
Can't read bool from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7f709555bca0)
Tried to access pin via an invalid ID P_RENDER_PASS_ENVIRONMENT (144)
Tried to access pin via an invalid ID P_RENDER_PASS_DIFFUSE_DIRECT (141)
Tried to access pin via an invalid ID P_RENDER_PASS_DIFFUSE_INDIRECT (142)
Tried to access pin via an invalid ID P_RENDER_PASS_REFLECTION_DIRECT (147)
Tried to access pin via an invalid ID P_RENDER_PASS_REFLECTION_INDIRECT (148)
ɿried to access pin?�P
ף=$�&�d�Ͽ
ף=y��6Mտ
ף=����ڿ
ף=��$���ݿ
ף=
Unknown pin ID 253
Unknown pin ID 253
Unknown pin ID 246
Unknown pin ID 246
Tried to access pin
JimStar
mac3d
Are you sure the OctaneServer running is the same 7.3 version as the running Blender Octane version? The server prints to the console its version right after start...
grimm
I was getting the similar errors when I tried to compile Blender for 7.2. I think my problem was that I didn't run "make clean" before running "make". I rebuilt Blender for the plugin version 7.3 and now I'm getting this error:
jason@gemong /usr/local $ ./blender
Read new prefs: /home/jason/.config/blender/2.73/config/userpref.blend
found bundled python: /usr/local/2.73/python
Octane: ERROR: Wrong version of render-server (7.3), 7.2 is needed
I did a "git pull" on the repo, is it not updated yet?
mac3d
Ok,I re-downloaded the new version of Blender Octane edition, installed and started according to the information, this is the result ..
./octane_blender_2.21.1-7.3.run -i
Verifying archive integrity... All good.
Uncompressing OctaneRender for Blender...
Installing OctaneRender...
OctaneRender for Blender was successfully installed.
Before rendering using OctaneRender from Blender you should run OctaneServer as daemon:
OctaneServer &
You can run Blender from /usr/local/OctaneBlender directory.
OctaneServer &
OctaneServer v. 7.3
Octane: Starting Octane engine...
Octane: ...started
Octane: Activating license...
Octane: found stored license info...
Octane: ...activated
Octane: LiveDB cache refresh started...
Octane: LiveDB cache refresh complete
Octane: ERROR: Tried to access pin via an invalid ID P_EXPLORATION_STRENGTH (42)
Can't connect node 'Daylight Environment' (NT_ENV_DAYLIGHT, 0x1b87730) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7f775824eca0)
Unknown pin ID 227
Tried to access pin via an invalid ID (227)
Unknown pin ID 227
Node type 30 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7f775824eca0)
That 's the error that I get from the command Octaneserver &
When you launch and run a blender render both the default cube that one scene the error is always the same ...
/usr/local/OctaneBlender ./blender -w
Color management: using fallback mode for management
found bundled python: /usr/local/OctaneBlender/2.73/python
trying to save userpref at /home/francesco/.config/blender/2.73/config/userpref.blend ok
Unknown pin ID 227
Unknown pin ID 227
Tried to access pin via an invalid ID P_MAX_DEPTH (97)
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7f775824eca0)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7f775824eca0)
Tried to access pin via an invalid ID P_LEFT_WORK_PANE (89)
Tried to access pin via an invalid ID P_ILLUMINATION (74)
Tried to access pin via an invalid ID P_RANDOM_SEED (135)
Unknown pin ID 242
Tried to access pin via an invalid ID (242)
Unknown pin ID 242
Tried to access pin via an invalid ID P_ON_OFF (118)
Unknown pin ID 229
Tried to access pin via an invalid ID (229)
Unknown pin ID 229
Tried to access pin via an invalid ID P_VARIANCE (214)
Can't read float_3 from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7f775824eca0)
Can't write float_3 to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7f775824eca0)
Unknown pin ID 228
Tried to access pin via an invalid ID (228)
Unknown pin ID 228
Tried to acc
Saved session recovery to '/tmp/quit.blend'
Blender quit
I do not know how to do :(
Sorry for my bad english
JimStar
grimm
The repo is not updated so far to 7.3. Will be updated at Monday.
Return to “Blender”
