Hey guys, I had this happen twice in a row and I'm hoping it isn't a GPU issue since I'm on a mac and it's hard to replace them.
my render was taking 1 minute 20 seconds per frame and then just stopped on a frame and stayed there. Kind of like it was hanging, for 16 hours. My GPU's memory or processor were at 5-10% numbers (i use istat) and i had to start the render again from that frame, which rendered normally. The render kind of just timed out.
Octane Hanging
- jeffbriant
- Contact:
- this is the still before restarting
- Screen Shot 2015-02-12 at 9.52.23 AM.png (10.57 KiB) Viewed 3143 times
2x1080's network rendering to 4x980Ti's
i can't see any good info here. Do you using info render passes in rendering?
- jeffbriant
- Contact:
I'm rendering only a beauty pass and an object id pass.
Here's my Octane log, it seemed to do it again just now. Says it can't read preset file at the bottom of this post.
Started logging on 12.02.15 09:59:57
OctaneRender version 2.16 (2160000)
---- FRAME 510 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:1 fullUpd:0 updMthd:0 nodes:0 links:0 ----
Tried to access null item
Tried to access pin via an invalid ID P_EFFICIENCY (38)
Tried to access null node pin
Can't connect node 'RGB Color' (NT_TEX_RGB, 0x7ff57ea78900) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node 'Zipper Line' (NT_UNKNOWN, 0x11ae380b8)
Tried to access pin via an invalid ID P_TRANSFORM (207)
Export materials time= 1732.467 ms
Collect objects time= 0.426 ms
Meshes creation time = 849.041 ms
Octane voxelization time = 0 ms
Sending to Octane engine time = 0 ms
Total export Time = 25546.822 ms
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0510.png -> 1
---- FRAME 511 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:132 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0511.png -> 1
---- FRAME 512 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0512.png -> 1
---- FRAME 513 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0513.png -> 1
---- FRAME 514 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0514.png -> 1
---- FRAME 515 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0515.png -> 1
---- FRAME 516 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - Asterisk_CanadaGoose/4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0516.png -> 1
---- FRAME 517 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0517.png -> 1
---- FRAME 518 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0518.png -> 1
---- FRAME 519 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0519.png -> 1
---- FRAME 520 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0520.png -> 1
---- FRAME 521 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0521.png -> 1
---- FRAME 522 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0522.png -> 1
---- FRAME 523 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Save result for file /Volumes/MEDIA 1/Dropbox/150110 - */4 - 3D Assets-Renders/3 - Rough Renders/4 - Jacket Roughs/2 - HybridgeLite 04/02_HybridgeLite04__ObjId0523.png -> 1
---- FRAME 524 DOC:0x00000001383D7F00 vpfps:24 rfps:24 first:0 fullUpd:0 updMthd:0 nodes:134 links:18 ----
Can't Read Preset File: /Applications/MAXON/CINEMA 4D R16/plugins/C4D - Octane 2.16presets.dat
- jeffbriant
- Contact:
Then this after i stopped the render
Could not load HDR result, because we have no render threads.
User break...
failed to tonemap render pass "Beauty"
Passes stored in:0.007 ms.
Tried to access pin via an invalid ID P_MESH (105)
User break...
let me know what says on info line as here? There is a problem with progress detection on render passes. Also please don't post bugs on seperate threads, keep them on version topics for next time. thanks
- jeffbriant
- Contact:
Ok my mistake. I don't know what you mean by "Info Line"aoktar wrote:let me know what says on info line as here? There is a problem with progress detection on render passes. Also please don't post bugs on seperate threads, keep them on version topics for next time. thanks
jeffbriant wrote:Ok my mistake. I don't know what you mean by "Info Line"aoktar wrote:let me know what says on info line as here? There is a problem with progress detection on render passes. Also please don't post bugs on seperate threads, keep them on version topics for next time. thanks
- a1.jpg (9.41 KiB) Viewed 3130 times
- jeffbriant
- Contact:
- andreroboredo
Same problem is happened to me. Changed DL kernel settings (rayepsilon and path term power) and it went back to render normally. I'm currently with a tight deadline so I had no time to search for the the issue. If it was actually kernel settings.
- jeffbriant
- Contact:
Thanks man, I just screwed around with the passes i was rendering out and it stopped. It sometimes hung on frame 1, or 5 or 10... kind of a pain until i got it working.andreroboredo wrote:Same problem is happened to me. Changed DL kernel settings (rayepsilon and path term power) and it went back to render normally. I'm currently with a tight deadline so I had no time to search for the the issue. If it was actually kernel settings.
