OctaneRender™ Standalone 2.21.1
abstrax
Just for your information: We built and uploaded a quick fix release 2.21.1 to fix the reported issues. Thanks for your feedback.
boeing727223
2.21.1 - UV issue fixed! :D
Dmi3ryd
I've very strange work of autofocus. Then you ckick in point in viewport image still blurred. Working incorrect :( In this situation help jnly one, manualy set distance.
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
jitendra
With this new version 2.21.1, the existing LUA script available here: http://render.otoy.com/forum/viewtopic.php?f=73&t=41365 has suddenly stopped working.
The frame creating function (Alt + A) is overwriting the .orbx file instead of creating a new .orc file.
I am not sure, if the problem is in the new build or there is some update requires for the above LUA script. :?
Thanks.
Best Regards, Jitendra
abstrax
Dmi3ryd wrote:I've very strange work of autofocus. Then you ckick in point in viewport image still blurred. Working incorrect :( In this situation help jnly one, manualy set distance.
Here it works. Is it possible that you have some transparent object in the foreground and you picked this one? You can select from all materials at this point by using the right mouse button for the various pickers.
Dmi3ryd
abstrax I've simple scene with 3 test spheres (diffuse material) and autofocus is missing. RMB didn't help because DOF is very high
abstrax
Dmi3ryd wrote:abstrax I've simple scene with 3 test spheres (diffuse material) and autofocus is missing. RMB didn't help because DOF is very high
Could you send me the scene? Thanks.
Dom74
any light in front of your scene ? light can catch focus.
Win7 x64 - 3DSMAX 2019 - 32GB RAM - 1080 TI
manalokos
We are doing a work still with 2.21.0 and the out of core textures saved us! Wonderful new feature!
But it seems a bit unstable, most of the time when we click another render target the GPU's that don't have enough memory fail.
Kind regards
Filipe
Dmi3ryd
Right now works fine. I don't know what was that, but I check focus at wireframe render. Working very good.
Could you explain me please what is difference between FStop and Aperture? Both are dependent and get same result :?:
