Scatter node help
justix
Phantom107 wrote:That is weird, they are not showing up here either. I think there is something else going on... any opportunity to livestream somewhere? Then you can PM me the link and I'll have a look at the workflow and where it goes wrong. :)
I see hat I can do, never done taht before but... I'm about to update to 2.1, did you tried that too? tha other concerne of mine is the out of memory from plane obj, did try on other objects like extrusions or solid and had no such things although NOT every obj imported get scattered UNLESS I use the Brush tool, I'll update with a video
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
Phantom107
There is something else going on. It works for me on Octane 1 as well as 2. Check your PM!
roeland
The scatter file should be exported in meters. Octane standalone doesn't have a setting to import scatter files in other length units.
I think the millimeter scale of the grass mesh is wrong too, it seems too small side to me.
Roeland
justix
roeland wrote:The scatter file should be exported in meters. Octane standalone doesn't have a setting to import scatter files in other length units.
Roeland
So the entire scene from Rhino should be exported in Meters? anyway, the phantom scatter tutorial (not saved from 1.52 ) works fine, I need now to tune several aspects of it BUT it work, except the scene saved from 1.52, upgrading to 2.1 (finally) but useful information as I thought that the importing in octane of scene in millimeters was sorted out a while ago...(?)
justix
what scenario is for the software in NOT prouce ANY area scattering? see obj attached 1M obj
cube.zip
(811 Bytes) Downloaded 125 times
Phantom107
OBJ models you import in Phantom Scatter should be in meters. Exported data in CSV files is always in meters because of that, not need to scale that in Octane.
justix
Phantom107 wrote:OBJ models you import in Phantom Scatter should be in meters. Exported data in CSV files is always in meters because of that, not need to scale that in Octane.
but the obj file attached in my previous post IS in meters BUT Phantom Scatter is not scattering any data on it, it is a solid split in 2 main surfaces were the scattering is to apply to the 'surface' material, it doesn't and it is not the first time that happen despite is just a stupid plane
Phantom107
Notice how in the source & range preview on the bottom-left corner on the screen, only a few bits are highlighted.
Try putting RANGE MIN to 0 and RANGE MAX to 100.
justix
Phantom107 wrote:Notice how in the source & range preview on the bottom-left corner on the screen, only a few bits are highlighted.
right..getting close to a better understanding AND use of your soft, one thing though, which value control the scattering to actually stay in the scatering area? I have my obj flying over AND spreading OUTSIDe the scattering area that I can see from the preview
Phantom107
1. Make sure the surface you are importing into Phantom Scatter is NOT double-sided. Phantom Scatter will work with the geometry you give it, so don't give it geometry that you don't want to scatter on. I take it this a Rhino OBJ exporting problem again?
2. My software will never put stuff ouside of the surface of the OBJ you imported. Make sure that the OBJ you are scattering around in Octane (the piece of grass) is placed at the center of the world (0, 0, 0). (as stated in the manual figure 06.1)
