Version 1.54.2 (Octane Render 1.54) *** 03.06.2014 ***
nehale
aoktar wrote:
nehale wrote:After copin the res file form version 2.06 i keep getting this error now
i think copying is not enough. Only you should revise some Real controls as Long as in 2.06
Sorry can you explain that more simple, do you mean i open it in a text editor and change the code?
Nehale
Windows 10 x64 | 2x GTX680 | i7 990X | 24GB
Cinema 4D R17 Studio + 3Ds Max 2017
OctaneRender™ for Cinema 4D 3.01 + OctaneRender® for 3ds max® v3.14
Pls use this package. I have revised all
res.zip
R16 resources for 1.54
(309.13 KiB) Downloaded 438 times
nehale
Thank you for the Fast response
That one works perfect!
Nehale
othiele
Apparently I have to purchase a plugin-license tu run this plugin, am I right? Standalone-License for 1.x isn't going to do the job or is it?
othiele wrote:Apparently I have to purchase a plugin-license tu run this plugin, am I right? Standalone-License for 1.x isn't going to do the job or is it?
1.54 is deprecated and too old. You may buy 2.xx licences if you decide to buy. I'm not sure that 1.x license is available.
Return to “Releases”
