Object Tag, Animation Update
coenbrasser
I've being trying to get my live viewer to update my animations, but I can't seem to get it to work.
What I'm missing here?
http://gyazo.com/fc2761ac20a2e26e1ee7e530bebf51a4
Scene: https://www.dropbox.com/s/9evpdwclr8dm1 ... t.c4d?dl=0
Fluffy
Works fine here. Make sure "Check Geometries" is enabled in the Live Viewer options.
coenbrasser
That's really weird, because I can't get to update.
http://gyazo.com/427418e00a4d829262470f570fe3b6e8
It only works when i manual press the render button, what else could I be missing?
There is no problem. See my image. what's your version, os?
EDIT: have you replaced and closed the opengl viewport?
coenbrasser
Well tried a re install, updated octane, did not do anything.
But I found out what went wrong, I had my live view as a tab in the same window as the view port, which was not visible.
When I pulled out the live viewer, so that the view port and the live viewer were visible at the same time the updates work.
Didn't expect it to be that.
coenbrasser wrote:Well tried a re install, updated octane, did not do anything.
yes, it requires a opengl viewport.
