OctaneRender® for Maya® 2.20 - 6.1 Win [OBSOLETE]
Moderator: JimStar
dsyee
Hi Jim - Don't know if this has been reported yet, but I first noticed it in 2.15.
If I create a new nHair system, then use the Attribute Editor button to assign a material to it (see attachment), I get an error:
Error: line 0: The attribute 'octaneGlossyMaterial1.outMaterial' cannot be connected to 'pfxHair1.octMaterial'.
It seems to work if I middle-mouse-drag from the Hypershade to the Attribute Editor, though:
Connected octaneGlossyMaterial1.outColor to pfxHair1.octMaterial.
Looks like it prefers the "outColor" connection and doesn't like the "outMaterial" connection?
Core i7-3770 / 16GB RAM / 2x GTX 780 6GB / Windows 7
itsallgoode9
p3taoctane wrote:I know you can import a material from the live data base. How about one from a saved local file?
Anyway to do this into Maya
Peter
this is my #1 request for the plugin. PLEASE add this. 8-)
Intel i7-3930K, 64gb RAM, Asus X79 Deluxe mobo, 2x EVGA 780 6gb (for rendering), 1x PNY quaddro k4000 (for display)
Windows 8.1 x64, Maya 2014, Octane Render v2
solomon
JimStar wrote:Thank you guys for reports. I will check it.
Hi JimStar, thanks for all the hardwork.
I have had to revert back to 2.15 - 6.0 Win for now, the 2.20 version is very unstable on my end. It's failing to render all my scenes created with the 2.15 version. I am looking forward to an update to 2.20
Solomon W. Jagwe
3D Artist/Animator/Modeler | Independent Film Director
http://www.sowl.com | http://www.galiwango.com | http://www.nkozaandnankya.com
dsyee
Peter
Can't you do this through the Hypershade?
File -> Export selected network... -> export as .ma
then
File -> Import
Or am I misunderstanding what the goal is...
p3taoctane
Lets say you made a really cool and complex material in the standalone. Save it your local database.
NO way to get that material/shader into Maya. You could save it to the Network database I guess.... but if you can import from there why can you not import from a local database ?
Peter
dsyee
Oh STANDALONE - missed that part. :)
Yes, this would be a great feature...
abstractmedia
Great work! Keep it up!
solomon
prodviz wrote:Awesome, cheers Jim.
I think the double sided material is in there as the 'Polygon Side'.
hi prodviz, can you please share how it works? do you have an example I can take a look at?
Solomon W. Jagwe
zurakan
. make octaneMixMaterial in amount option use octanePolygonSideTexture
octaneMixMaterial ==== meterial 1 is outside
meterial 2 is inside
:D
Win7 Ultimate x64 xeon Core 40 / maya2Octane 1.20a , maya 2014SP4 & Octane 1.50,
128GB Ram, 4 x GTX Titan 6GB
prodviz
:D
Cool, cheers. I hadn't tested it yet. :D
Return to “Autodesk Maya”
