Version 2.16.2
shawnfrueh
iNews wrote:Hi!
Net render work only two slave.
other slots can not see (
2+4+4=10
The max amount of cards is 12, How many are on your main machine? You may have to disable one or two of the cards. If one of the slaves has one or more over the amount octane will not use it. This is a standalone issue(?).
-Shawn
sparkworld
We're getting crashes on our macs when we import anything that has Octane shaders on it. If we do the conversions once the object is in the scene then we're fine. On our PC, no problem.
But wait it gets better. If we copy a file on the PC and save it to a blank file, then everything works fine on the Macs. I would love to say that it's a corrupted file that we opened but it was any file (whether it was Octane'd or not) with an Octane'd file pasted in that caused the crashes. Right at the moment of pasting. And again only on the Macs.
Also on a 60 hour render fest we had no crashes on our PC but three crashes on the Macs in very random fashion. Easy to re-boot and start where it left off but we couldn't get it to crash in any way that made sense in either Render queue or Picture viewer. Pretty random, I'm afraid.
Let me know if anybody else has been getting this. And (I think I know the answer to this) can you save to an earlier Octane version?
sparkworld wrote:We're getting crashes on our macs when we import anything that has Octane shaders on it. If we do the conversions once the object is in the scene then we're fine. On our PC, no problem.
can you post bugreport.zip and a bad scene which causes crashes from mac?
EINBLICKE
I have installed this version. The hdri is invisible in the viewer. I can load it, but in the live viewer it is invisible! It also does not radiate to the scene. What´s wrong? Please help!
EINBLICKE wrote:I have installed this version. The hdri is invisible in the viewer. I can load it, but in the live viewer it is invisible! It also does not radiate to the scene. What´s wrong? Please help!
which hdri?
EINBLICKE
which hdri?
No matter what. I load an hdr image in the environment tag and the result is, the background in the live viewer is white oder grey, no hdr image is visible.
EINBLICKE wrote:
which hdri?
try this scene to see. Post results. Where is your hdris?
background_and_matte.zip
(200.36 KiB) Downloaded 238 times
EINBLICKE
EINBLICKE
EINBLICKE
the first is your´s with jpg. texture environment
the second is my with hdr environment
Return to “Releases”
