Hi! I have installed the version 2.16 for cinema but the renders and live viewer are totally black... Is working perfect with version 2.12
I am making something wrong?
Version 2.16.2
no, 2.16.1 has fixes over test3.dinf wrote:Hey Ahmet,
is 2.16.1 identical with Test 3 or the latest Version after that?
Thanks.
yes, likely. Do you see any gpus on settings? I have wrote requirements on install notes, please check again.szoraidez wrote:Hi! I have installed the version 2.16 for cinema but the renders and live viewer are totally black... Is working perfect with version 2.12
- inlifethrill
- Contact:
Additionally, make sure you check the default environment color. It defaults to black with fresh installs. Check the image attached.
I have notified today, there's a mistake on clean install. it assign as black, will be fixed on next.cyartist wrote:Thanks great tip!
- kehrmaschine
Ok.. I just updated to 2.16.1 because I had a problem with 2.06.
Now I can not render in 2.16.1.
When is this gonna be fixed?
Which version is best/stable for Win7 64 C4D R15? And where can I download it? I can only see 2.16 and 1.00 in customers area...
2.16.1 is stabile candicate.kehrmaschine wrote:Ok.. I just updated to 2.16.1 because I had a problem with 2.06.
Do you see any other criticism about stability here? Please post more info about problem to help to you.
Please don't post on several places. This makes me confused. I think you should set this default environment color as in image.
Also post images to describe better your problems. I cannot estimate what happens.
