Version 2.14.0 - TEST
sadece
I've just noticed something weird. i a have an object which has emmison polygones. i used mograph to duplicate. see what happens with/without checking "render instances"
http://www.sadece.com.tr
i7 990x // 12GB Ram // 2x Titan X + Titan + 780 // Octane for C4D // Win7 x64
sadece wrote:I've just noticed something weird. i a have an object which has emmison polygones. i used mograph to duplicate. see what happens with/without checking "render instances"
when you don`t use object tag, all objects will be collected a single mesh. but object tag exports all as individual meshes. but situation is different o render instances. they are always exported as individual meshes.
so what's the relationship for your problem?
emissions seems different due polygon area. on your first images, 3 objects are a part of big single mesh. check octane node graph to see what happens actually
sadece
Thanks for the info.
Btw is it right behavior for the emmision materials are related to size of objects? Same emission material on a huge sphere and a tiny one, should the brightness be same ?
sadece wrote: Thanks for the info.
i think so. Seems like that reflects same amount of illumination without accounting size. this explains why collected meshes don't casts the illumination for each boxes as a indivual mesh.
Dean
Hello,
I have a problem with the rendering of animated textures.
The same setting final render is different from that which shows the preview window.
Illumination is also different.
Preview from Octane window
Final render
atome451
About importing .ORBX materials from standalone (in LocalDB or not) or savings in the OctaneLive DB storage from C4D.
When you import complex nodes structure with cascading mix materials in .ORBX file format from the standalone or from materials made in C4D and saved in the OctaneLive DB storage, even if you rename the mix materials nodes in the standalone or in C4D, these are all named "Octane Mix Material" when imported back in C4D. With complex materials, it's sometimes time consuming to find the right final mix material to connect to the object(s).
Aoktar, do you think it's possible to restore the name of the mix material nodes from the .ORBX file in the C4D material manager? It could be wonderfull! :)
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
atome451 wrote:About importing .ORBX materials from standalone (in LocalDB or not) or savings in the OctaneLive DB storage from C4D.
ok, will try to fix for 2.16 ;)
atome451
Great! Thanks a lot! :D
Oleg
What is that in the bottom corners, some sort of red vignette? Showed in wire mode
