FiberFX rendering in LightWave 2015 !!!
atnreg
juanjgon wrote:Yes, this seems a LW problem. Check your scene with the "soon to be released" ;) new LightWave 2015 to see if it is fixed now.
Ok, I'll wait for the new release then, it's just strange that this does not occur until I activate and use Octane in a scene :)
juanjgon wrote: Currently to work with Octane and FiberFX you need to enable the fiberFX node editor and set a Octane material inside linked to the material input to avoid problems and error messages. Anyway you need to add a Octane material to shader your hair.
Yes that's true, it's just annoying that the message pops out all the time, is that message actually necessary and if so, could it be only at status bar, then it wouldn't bother? :)
But do you think I should send the scene to you to investigate?
Antti
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun :)
juanjgon
Can you please send to me the.cube scene that crash Layout?
atnreg
juanjgon wrote:Can you please send to me the.cube scene that crash Layout?
Yes I can but actually I found out the cause.
I did the test using Layout Modeler Tools to create a cube but did not check the 'save object'. Then I loaded the scene and of course the cube was not there so I added it again, this time with 'save object' checked. But the missing object was there as Null and that caused the crash. When I loaded the scene and deleted the Null, it worked fine.
The only strange thing is that if I now add a simple Null, it won't crash so the Null made by LW not finding an object is the cause.
But just in case you want to check it, here it is as attachment :)
Antti
crashtest.rar
(11.08 KiB) Downloaded 196 times
atnreg
That update just arrived and I installed it but it did not change this behaviour...still if I set 'eye' on in FiberFX, Layout crashes just after loading the scene.
Also the cube test above behaves exactly the same as before.
I also noticed that if IPR is open and I turn off the FiberFX for a surface (click the little dot to turn it off it in FiberFX), Layout crashes immediately. If I 'switch to LW' in Octane menu, that does not happen in VPR.
Could these still be Octane problems and not LW itself? :)
One more little purely Octane issue: if the 'eye' is off, IPR does not update the geometry even though that option is on in Octane, it needs reload. If the 'eye' is on, IPR updates when FiberFX values are changed.
I have not played with FiberFX until now, that's why I haven't noticed these before :)
Antti
juanjgon
Can you please also send to me the scene with the "eye" problem? ;)
atnreg
juanjgon wrote:Can you please also send to me the scene with the "eye" problem? ;)
Yes of course, just sent you a Private message :)
Thank you!
Antti
tmclemons
Hello Juanjo I need your help,
First off thanks so much for all you've done for the lightwave octane integration. Second, I need help I am having issues with my Fiberfx render. I am using guides to drive fiberfx hair style and i get these weird polygons showing up throughout the fiberfx flow as a render it in octane. Please advise thanks!
fiberfx polygon issues
Quadro K2000 2gb, quadro k600 1gb, quadro 600 1gb
juanjgon
tmclemons wrote:Hello Juanjo I need your help,
Weird, I never have seen this problem before. What version of the plugin and LightWave are you using?
Can you send me a scene to reproduce this problem?
tmclemons
I am using lightwave 2015.1 and octane 2.16 standalone and lw plugin. I will send you the packaged scene very soon. Thanks for the help
tmclemons
EUREKA
I do not know if this is the standard process but i figured out how to fix it, apparently when using guides for fiberfx, the octaneobject property setting on the guides have to be activated aswell ( like if you were using 2 point poly chains for fibermesh in the pre-lightwave 2015 hair process) once both are activated the octane fiberfx with guides process works.
fiberfx fix
fiberfx fix
Return to “Lightwave 3D”
