mirror number of reflections
macchiorlatti
If I use a mirror material can I control the number of reflections in the other mirrors?
In the attached image the secondary reflections are black: can I avoid that?
thanx in advance
mac
Seekerfinder
Hi Mac,
Which kernel did you use? DL is not so good for specular materials. If you used pathtracing or PMC in your example, I can't help but if you post that question under the general forum you're likely to get a quicker response. Let us know which kernel you used either way.
Best,
Seeker
macchiorlatti
Thank you Seeker,
I've tried three methods and the Black block appears only inthe Direct light method;
see attached images
excuse my late answer but I'm very busy
mac
PMC
PMC
Path tracing
Path tracing
DL
DL
Seekerfinder
Mac,
There might be some tweaks you could do with dome settings but I won't be surprised if you're stuck with that result on DL. Better results with PT anyway and recent speed improvements makes it a much more viable option.
Best,
Seeker
FooZe
Check the depths in the Kernel settings http://render.otoy.com/manuals/Sketchup/?page_id=673
macchiorlatti
Thank you Seeker and thank you FooZe,
I've tried Specular depth 5 and glossy depth 5 (same), and the result is good with Direct Light. Render time is almost the same.
Sometimes manuals are pretty obscure for me...
very well
Specular depth=5, Glossy depth=5, DL method
fuzzybro
Hi macchiorlatti,
If you're still having the issue, could you please tell which Octane4SU version are you using?
Also could you please export the scene to .ocs/.orbx and open it in Standalone?
There is a chance that one of the controllers in DL kernel is broken (specular/glossy bounces). Try tweaking then in the Standalone and see what happens.
Hope to hear from you soon,
Fuzzy
macchiorlatti
my octane4SU version is 0.13.82
and works pretty well, octane is a new render software for me...
thanks
fuzzybro
You might want to try the most recent one which is 0.13.87 (there are couple of tiny fixes).
But anyway.. have you managed to figure out the issue with reflections?
Cheers
macchiorlatti wrote:my octane4SU version is 0.13.82
thanks
macchiorlatti
hi FUZZ,
I,ve installed "octane_sketchup_0.13.87_2014_x86", but the "about" rollout says 0.13.82 , I've checked the "repair" button, I don't know if I'm doing something wrong: I'm new with Windows 8.1.
The reflection issues are solved also In DL mode
thanx
OS is Windows 8.1 pro, I use SKP V14,
hardaware: Intel i7-4820K 8 cores,
32 gb Ram, geforce GTX 780 direct CU II 3GB, 1 HD SSD 240 GB (softwares), 1 HD 1 Tb (data).
Return to “SketchUp”
