OctaneRender 2 for Revit [OBSOLETE]
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
I have updated the installer links at the top of this thread to the latest TEST build (2.12.1.19). Pls see the TEST thread for release notes.
Seekerfinder
face_off wrote:I have updated the installer links at the top of this thread to the latest TEST build (2.12.1.19). Pls see the TEST thread for release notes.
Hi Paul,
So it's exactly the same build that's on the test thread?
Seeker
Yes. Plugin version 2.12.1.19 is looking to be very stable - so time to migrate it here before I post a test build for 2.13.
Seekerfinder
Ok, cheers Paul.
Seeker
andredms
Hello Paul, I'm experiencing a strange behavior with the 2.12.1.19: on the space between two building pads, and at the immediate surroundings, the displacement property of materials applied to the topography do not work.
Can you post a screenshot of the render and the material with the displacement applied pls?
andredms
Thanks Andredms - What is the specific problem with those renders pls? You can lower/raise the top of the grass with the displacement Offset slider.
andredms
face_off wrote:Thanks Andredms - What is the specific problem with those renders pls? You can lower/raise the top of the grass with the displacement Offset slider.
There's no displacement whatsoever, around the building pads - in all those pictures the scene and texture parameters are exactly the same. Take a look at the pictures with the bp near or far away - at the distance of the building pads, the grass displacement "arises". This problem does not happen around the floor objects.
I am sorry - I don't understand. What is a "bp"?
displacement_error_2_one-floor_without_bp.jpg seems to have displacement around the building pad.
Return to “Autodesk Revit”
