I upgraded from some older GTX 580, and GTX 680s (For sale if anyone is interested...PM me)
I run an older Quadro FX 5800 that used to run my monitors off. I want to switch the monitor duty to an installed standard titan.
I currently have 3 z's, a standard titan and the Quadro FX 5800 in my box.
All the monitors are plugged into the standard Z which runs fine... but when I take the Quadro out even though nothing is plugged into the system will not boot up.
If I place it back up into " (one particular PCI slot) up comes the system. How do I tell the system to ignore it?
Thanks for any tips
Peter
Titan Z and Quadro FX 5800 Issues
- p3taoctane
maybe it boots up but you should check which gpu has output?
- p3taoctane
Sorry what do you mean by output?
Did you check in bios your PCI express settings ?
- p3taoctane
What is this strange magic you speak of. Are you wizards??
When booting up in the bio screen what the heck am I looking for... its all blue
Sorry for being light hearted... but I am concerned that I might turn it off and then turn on another that is the wrong one.
How will I know what is the Titan Z or standard Titan?
If I find a Primary Video Controller/Adapter. Do I get to choose which one is the main "output"
Any non magic ideas welcome
My fault. I'll try to be more precise:
I had similar issue when I added a gtx titan to 3x780s. What worked for me was changing settings in bios - the primary display to PCI x16 (from auto) and connected all monitors to a graphics card that is closest to a cpu. Then I had to reinstall nvidia driver.
I also noticed that the primary display had to be connected via DVI cable (I had some issues with display port).
- p3taoctane
Not at all, your reply was fine. This is such a helpful forum. Everybody shares experiences and info.
I'll try your suggestions I am sure that will work
Many thanks.
Many thanks.
