OctaneRender™ Standalone 2.15
geo_n
FrankPooleFloating wrote:
geo_n wrote:
:? Geo, you are aware that even a single GTX 480 would smoke your three GPUs combined, right? Not picking on you. I was just under the impression that you were working at a certain level - and these wimps tell a different story. You should pick up a 580 or something on eBay. No one working in Octane (even a hobbyist) should be using anything less than 70s or 80s...
I haven't used octane for work at all. I tried to but its not there for me yet. Simple things like exclude from shadowcatcher doesn't work...
At work we all use vray and it will not change anytime soon, maybe never, the pipeline is heavily based on it.
I use lightwave at home and its renderer is quite complete except for micropolydisp and hair which I bought octane v2 for. I want octane to grow but I'm just playing with it right now so I havan't invested big money yet on gpu. Just two used 750gt ti(which will smoke 480gt in price/perf/efficiency) is enough which roughly equals two of my I7 in render speed.
stratified
Elvissuperstar007 wrote:panoramic camera not working
Can you post a screenshot because it's working fine on my machine.
cheers,
Thomas
Elvissuperstar007
cheers,
Thomas
abstrax
Packages (.ORBX) need to be unpacked first, before you can save them via File -> Save... . Packages are for moving projects around, not for working on them. If you accidentally made a change in a package, before you unpacked it, you can save it as a new package, then load the new package and unpack it.
The material preview camera can't be deleted and therefor can't be replaced by a panoramic camera. That's by design. But in a normal scene or even in the regular preview render target you can replace the camera node by a different one.
JeffGalloway
Does the new exposure system have any relation to photographic EV?
I notice form this http://www.fredparker.com/ultexp1.htm#L ... ty%20Chart chart that the EV for a sunny day should be 15.
I have to set the Octane exposure value to around 1 to get a proper sunny day exposure.
abstrax
JeffGalloway wrote:Does the new exposure system have any relation to photographic EV?
Not really. With this release we increased the exposure by about 40%, to make the texture environment exactly match the rendering at the normalized environment. If you then switch to the daylight environment you will see that the rendering is overexposed, because the daylight is way too bright compared to the texture environment. This ratio is pretty much just arbitrary. With next version we plan to correct that, i.e. the daylight system will be darker with the same power setting as before.
I will also put a little Lua script graph into the Lua scripting forum that allows you to apply an EV compensation like in a real camera.
aLeXXtoR
Wow, thanks!
Guys, is it possible to return the "Aperture" pin to the Alembic node to make aperture value adjustment possible inside the Standalone? I really miss this option. :(
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
a couple of bugs in the osx version, at least on my system:
if you try to resize any window, octane stops to respond.
if you create a new material node, as soon as the material ball scene is loaded, octane stops to respond.
ciao beppe
daveyt
Thanks for the update otoy team,
I was wondering if was possible in a future release to be able to have a different viewing resolution to the rendered
res, ie when rendering at 4000x2000 in the view port its at 1000x500,
best regards
Daveyt
gtx 580 3gb gtx 660ti 3gb win 7 blender 2.65
smicha
daveyt wrote:Thanks for the update otoy team,
res, ie when rendering at 4000x1000 in the view port its at 1000x500,
best regards
Daveyt
hold ctrl+ scroll
