Blending Dirt and ImageTexture?
MoGrafik
Just took a look at the video tutorial. So awesome! Thanks so much! EXACTLY what I've been looking to achieve. Thanks for the great tutorial!
Win 8.1 / i7 4930k / 2 x GTX Titan / Cinema 4d
gordonrobb
Fantastic thanks. C4D's method for texturing is vastly different from Lightwaves, but I think I got the gist. I look forward to playing.
Savi089
Fantastic tutorial, thank you Blastframe!
Win10 | Ryzen 7 1700 | 1x 980ti + 1x GTX1060 + | 32gb | Cinema4D and Octane Plugin
pxlntwrk
Hi, a little thread up
pretty cool vids :D
@blastframe :in addition to your nices procedural materials, i notice that dirt shader loose some edges to "dirtify" with object little bit more complex.it's due to the shader itself and normals matter , i presume :).
Therefore each should I use the dirt shader with objects having concavity, I double the dirt shader node in a multiply node, not forgetting to check or uncheck the "invert normals" box.
im not sure im clear :?
Here are the results in images with a simple and double node shader...
ciao
pxlntwrk.net
virtualzapp
blastframe wrote:I just posted a video tutorial showing a technique for mixing a dirt map with noise:
I'm trying to test the dirt shader and there is something I don't understand by following your steps.
For some reason, I can't put the turbulence in the dirt map…like you show at the beginning in your great tutorial.
I'm using the last version (2.12.2) of octane for c4d on Mac.
I've attached the cube test scene, is it coming from my octane version or did I really miss something?
Regis
test.zip
test scene
(92.66 KiB) Downloaded 307 times
VFX compositor / CG generalist
Mac Pro 12C 2.93GHz, 64gb ram, 1xGTX Titan X, 4xGTX Titans in Cubix
you can use mix or multiply node to combine a dirt and turbulence. Also check new noise node. it's much better than turbulence
virtualzapp
Thank you Ahmed, always here for us ;o)
Cheers
Regis
virtualzapp
aoktar wrote:you can use mix or multiply node to combine a dirt and turbulence. Also check new noise node. it's much better than turbulence
Based on the advice of Ahmed, I found out this method, see attached screenshots.
Hopefully it might help someone ;o)
Cheers
Regis
djart
i just tried to create the shaders from blastframes tutorial here http://vimeo.com/100085092
I was able to reproduce until minute 10-11. At that point i got totally lost cause whats happening on the tutorial i can´t reproduce. For me all the "going up, going one down and so on" in c4d´s crazy layer managment is very confusing. I am not lazy and usually very patient, but this drives me nuts...
Maybe someone might be so generous and load up the final shaders from the tutorial for a reverse engeneering session or post a screenshot from the c4d´s nodetree.
And any help is appreciated.
Best Regards,
djart
pxlntwrk
I also tried to reproduce this Blastframes tutorial and heres the result:
This is not exactly the same result but I link the file if it helps :?:
http://we.tl/HrUc8CQGl3
ciao
pxlntwrk.net
