OctaneRender® for 3ds max® v2.13
bicket
Hi Karba
:( Border mode of the displacement map doesn't work
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
oguzbir
Karba Hi,
I assume you're working on the next build.
I wonder if it would be possible to add a feature that would mean a lot to us.
I'll be asking for an override material feature. Like clay mode, you implemented earlier. But this time we could have our custom render passes manually. Which is kinda cool.
it's really necessary for me to render a single material for all objects in the scene. I do it for my custom passes.
We can do this by saving another file. But its just not feasible to save all other custom passes.
This would really speed my workflow.
thanks,
My Portfolio
HHbomb
I just realize that in network render, there is no more info from number of rendering GPU.
Is there an option or it is no more visible ? It was a good info...
oguzbir
There is a bug in saving render passes.
I rendered output to a png file
added indirect reflection and indirect diffuse saved also as PNG.
The result is below.
Sorry if it's reported earlier, elsewhere..
Edit: Direct Diffuse pass renders in octane viewport. ( if you press port to max buffer )
Direct Diffuse pass renders black if you do a MAX's final render.
My Portfolio
User avatar (Default)
merid888
the versión 2.13 is so slow a simple image with direct light and ambient oclussion took a 5.51 minutes with 500 maxsamples and 1000 x 800 px
anyone can help me, please
add image
mbetke
Many alphamaps used on the textures maybe? It slows things down.
VRay supports some kind of filtering option that can be turned off for alphamaps and it speeds stuff really up. Octane doesnt support it. :(
You can also try to check "coherent mode". Maybe it helps too.
PURE3D Visualisierungen
Sys: Intel Core i9-12900K, 128GB RAM, 2x 4090 RTX, Windows 11 Pro x64, 3ds Max 2024.2
DIO
HHbomb wrote:I just realize that in network render, there is no more info from number of rendering GPU.
+1
Just updated all machines to 2.13 and Net GPU info is missing.
Could you please bring it back in the next release ?
corei7-4930k 6 x 4,0 Ghz, 32GB RAM, 2x 980 Ti
Win7 64bit, 3dsmax 2014 / 2015
merid888
no many maps, just diffuse maps, no alpha maps, i'll try with coherent mode
thank you for comment
coilbook
+1 I spent 30 minutes thinking my network was messed up
oguzbir
New Bug.
Disabling "Elements Active" checkbox doesnt work.
it still outputs render passes if you press port to max buffer window in OCt. viewport.
My Portfolio
Return to “Releases”
