The method of setting light to the interior of many light so
Goldisart
Friends !!! Who was involved in setting up the interiors ?
Optimization of the configuration of the light - Lessons .
Especially when light sources are many and they each need to configure
glimpse
hi, Goldisart,
show something =) as every situation is a bit different it would help to have at least a direction You're heading =)
Goldisart
About light under the glass I already raised the problem - solution as I realized one thing to wait long. maybe there are fake to minimize the calculation time Maybe I do something wrong 1. I turn off the light all 2. I set up my first small light sources and gradually go to great 3. I include the environment and set light
Goldisart
the light above the glass - render time decreased
Goldisart
Here is my question - are the objects in the scenes which are not needed in the accurate processing of glossy depth - for example glossy wall - it will take a lot of time to count it pure. Are there any options ? for example, the fake material which will - see pic
kcpr-raffaEl
You can try to reduce reflection noise by changing hotpixel_removal value in Octane Camera settings.
This is strange, but value "1" means no removal, and lower values resulst in stronger noise reduction effect.
coilbook
Goldisart wrote:Here is my question - are the objects in the scenes which are not needed in the accurate processing of glossy depth - for example glossy wall - it will take a lot of time to count it pure. Are there any options ? for example, the fake material which will - see pic
nice to know about glossy depth Thanks
Would be cool if they can add smooth out noise feature for lights
Return to “Autodesk 3Ds Max”
