Hey there
When clicking on all directories with subdirectories and some subdirectories (not all), all I can see is 'MSG:loop' and no materials, any suggestions? I'm using Win7 x64/R16/2.06.
Error in LiveDB - 'MSG:loop'
update your version. thanks
Also, just to hijack my own thread with another question rather than start a new one... the 'Lock resolution' button doesn't seem to stick (in 2.06 or 2.14) when sending/restarting a render (see attached video). This isn't the correct functionality, right?
Thanks for the help.
- lock.mp4
- (12.99 MiB) Downloaded 2338 times
we don't expect this lock behaviour. It should be sticked as you click. What operation will cause this "msg loop"? I can't see this
- Stephano_22
I get the same MSG:Loop error when I access multiple categories for example
Otoy/sign,vent
Texture/plastic
I just assumed it meant there were no textures in that category. I too am using Win7 x64/R16/2.06.
I am still using the last stable version 2.06. Interesting that OP is stating the same issue after upgrading. On that note is there a thread that can direct me on how to upgrade (mainly about deleting current version and if I need to deactivate license then reactivate in new version?)
Steve
Otoy/sign,vent
Texture/plastic
Steve
Hi guys,
i have checked this. But some caterigories are really empty. So there is no problem about livedb. You can/should use the standalone for sometimes to check issues. It's same on standalone.
Upgrade is really straight. Just download zip file from topics and remove old files and copy new one. No need to reactivate.
