OctaneRender™ for Blender 2.06 - 6.6 Win [OBSOLETE]
JimStar
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Internal motion blur is implemented. Subframe motion blur feature is not removed: now you can choose between "Internal" (faster) and "Subframe" (more universal).
  • Fixed bug: grainy image in frames without any changes if subframe motion blur was used (reported by aLeXXtoR).
  • Minor fixes...
Blender Octane Edition - 6.6 (2.72) (57.3MB autoinstaller file)
Octane Server - 2.06 - 6.6 (8.9MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.06 - 6.6 (8.0MB autoinstaller file)
aLeXXtoR
That's great! Thank you! :)
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
RajivMudgal
Fantastic
Cheers
-RM
Rajiv Mudgal
Film Maker and VFX Creative Director at DarkWhite Productions
Win 10 64 |3X Nvidia Titan | i7 5820k | 32GB
Alain
I had this Error:
Solution:
Download the Blender 2.72b Zipfile from blender.org and copy MSVCR120.dll, MSVCP120.dll and vcomp120.dll from that Zipfile to the same Folder of Blender Octane Edition.
Kind regards
Alain
Intel Pentium 2.8 GHz 2 Cores, 8 GB RAM, GeForce GTX Titan 8GB, Blender 2.72b, Win 7 64 Bit
ROUBAL
I already signaled these missing dll in the previous version... :roll: maybe too late just before this release.
Alain
Tested a simple Scene with a Carpet (Particlesystem distributes a Carpetpatch over a Plane).
It works when I set the Emission Number to 10.
But when I set it to only (!) 100, then the hole Operationssystem gets very slow, almost frozen and it seems not to render (I did restart the Computer after >5 minuntes of waiting).
Here is the File:
Blender_Octane_Carpet_Test_01_291114.zip
(1.6 MiB) Downloaded 278 times
Basic question: Instancing is supported, right ?
Please tell me what I do wrong.
Kind regards
Alain
PS. Im using the DEMO Version of Octaneserver 2.x
kubicki3d
Alain wrote:Tested a simple Scene with a Carpet (Particlesystem distributes a Carpetpatch over a Plane).
Hi Alain,
Set your carpet patch mesh type to Scatter, as in the screenshot below.
carpet scatter
carpet scatter
Hope this helps
Szymon
i7 5960X | 64GB RAM | Win10 Pro | ASUS X99 Pro mobo | Chieftec 1250W psu
MSI GTX 780 Ti OC 3GB | 2 x GIGABYTE GTX 780 OC 3GB on USB risers | MSI GTX 750 Ti for display
Blender + Octane | C4D + Corona
Flickr profile: http://www.flickr.com/photos/kubicki3d
dafassi
Hey! Just tryed to composite with alpha chanel (quick test).
As you can see in the rendered viewport there are white borders around my objects (not everywhere).
When saving the alpha-sequence and composite it in an other application, the white borders are there, too.
What can i do against that?
Greets,
dafassi
White borders
White borders
WIN7 64bit • 32GB DDR5 RAM • Intel i7 6x4GHz • GeForce GTX780 • Blender
kubicki3d
dafassi wrote:Hey! Just tryed to composite with alpha chanel (quick test).
Hi dafassi,
Do you have Premultiplied alpha turned on?
Cheers,
Szymon
dafassi
No, thats what i was searching for.
Thank you for helping.
Wondering why this is under the camera menu- not under the render-settings?
Greets!
Return to “Blender”
