octane for rhino, hdri and lights
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
dvidalis
hello everybody,
new in octane and i am trying to set a scene with a nigth sky (hdri) but alla the lights of the scene do not appear at all. any ideas? is it a setting i am missing here???
Thanks in advance :D
FooZe
Are you happy to post a couple of screenshots of what things look like so far?
dvidalis
well here are some printscreens. in the 1 there are no lighs only the hdri. in 2 there are lights in the black cyrcles but they do not appear in render. i use demo version, is it the reason it does not work?
Hi - can you post a screenshot of the Material which is applied to the geometry in the black circles in 2 (ie. we need a screenshot of the emitter material)?
dvidalis
well this is an old 3d project i just used to see how octane works. i have made it with vray materials. i wiil attach the material so you can have a look (vismat format). i have also made some tests on simple forms without materials and does not work either.
Wall_04.rar
(626.03 KiB) Downloaded 363 times
I'm really sorry but unless you can provide me with the information I originally asked for (a screenshot of the emitter material) - is it very hard for me to help you.
The rar file you posted does not have a Rhino file enclosed in it.
Vray materials will convert to Octane materials via a Rhino material (so it goes Vray material -> Rhino material -> Octane material) - so if VRay does not correctly convert the emitter material to a Rhino emitter, it will not convert to an Octane emitter.
dvidalis
i don't know what the emmiter is. first time to hear it. if you can explain where to find i can for sure sent it to you. i could only find this in properties(image 1)
thanks a lot for your patience
Dimitris
Octane does not use "lights". It uses daylight, IBL or light emission from geometry. The plugin manual cover these in the following section: http://render.otoy.com/manuals/Rhino/?page_id=72.
dvidalis
ok found it and i think i am getting somewhere, emmiter_3 works but sends light up while emmiter_4 is the same eith the manual. i think i have to make some more tests. thanks a lot for your help.. :D
Return to “Resources and Sharing”
