NOTE: Using Octane Render for Blender v2.06 - 6.5
I have set up an HDR texture as the World - Environment presets - Texture image using an Octane Image Node and it is working. In the Octane Render for Blender manual (http://render.otoy.com/manuals/Blender/?page_id=77) it shows a "Rotation:" section just under the Texture display and instructs to use that to rotate the image - Quote "Rotation - If the environment is not in the correct directional orientation, it can be adjusted in real-time by using the Rotation parameter."
The issue is that I wish to rotate the image but the "Rotation" section is no longer available (please see screenshot below).
Can anyone suggest how I can rotate the Environment Texture?
Any advice is appreciated.
v2.06-6.5 - How to rotate HDR environment texture
- Flange4789
i7-3770K @ 3.50GHz | 16GB RAM | GTX TITAN-Z | Win7 64bit
Use the Full Transform node, as in the screenshot below (X-Translation). Best,
Szymon
Szymon
i7 5960X | 64GB RAM | Win10 Pro | ASUS X99 Pro mobo | Chieftec 1250W psu
MSI GTX 780 Ti OC 3GB | 2 x GIGABYTE GTX 780 OC 3GB on USB risers | MSI GTX 750 Ti for display
Blender + Octane | C4D + Corona
Flickr profile: http://www.flickr.com/photos/kubicki3d
- Flange4789
Many thanks!
Sorry for bumping in, but it´s not working with the current version (2.25-9.11)
Anyone else having this issue?
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
Maybe try changing units under scene settings - in the past some users reported that Metric (or None? Can't remember...) don't work, although I've never had any issues with that...
