Is there like a default rendering make?
jang2235
How to create a basic rendering Fog Render like ??
juanjgon
Can you send to me this object to test it here? ... it has a weird artifact in the Octane Z-Depth render. Perhaps the model has a problem, or there is a bug in Octane.
atnreg
I may be on totally wrong path with this but just came to my mind from my experience (and manual) that Octane does not like other than Tris and Quads. I had some very strange results when I had a cylinder that had not been Poled. Try to Triple the object and then try again :)
Antti
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun :)
UnCommonGrafx
If you have LWCad then "Make Quad" or "Make Convex" will fix those problems.
Otherwise, go with what Antti said.
i7-4770K, 32gb ram, windows 8.1, GTX Titan and gt 620 for display
jang2235
Test Scene upload
Test_Scene.zip
(953.67 KiB) Downloaded 188 times
juanjgon
I think that this is not the scene with your problem. Please check it ;)
jang2235
All my mistakes. Was uploaded again
Test_Dissolve.zip
(1.41 MiB) Downloaded 196 times
juanjgon
The problem is the dissolve effect in the object. Dissolve in Octane works with the opacity channel of the materials, so I think that it doesn't have the same behavior than in LW. You are making the object transparent, and the Z buffer has wrong data from the polygons inside the object
Anyway a Z buffer in a transparent object has no sense (this is not the real distance to the object surface), and at least for a fog effect I think that you should disable the dissolve feature. In this pass render all the objects without transparency or dissolve effects.
Return to “Lightwave 3D”
