Hi there, apologies if this has already been resolved somewhere.
I'm half way through my first commercial job using octane render and it's all fine except for a strange bug I'm encountering when using normal and displacement maps on the same material.
When using both simultaneously there is a weird diagonal line between each face (basically splitting quads into tris) and the normal map gets inverted on one half of the quad. It's quite a bizarre effect, I hardly noticed it at first as I'm using a very subtle paper texture in my normal map so it wasn't hugely visible.
I found someone talking about the same issue on the lightwave forum but didn't find it here - are there any fixes or workarounds for it?
Cheers.
Displacement+Normal Map bug
short answer - You can use both of them, should stick with one. I'd advise simply combine those two & use one higher resolution texture.
Maybe an explanation: i've made a quick test with a noise inside the C4D effect > Normalizer and the result give this kind of curious triangles inverted normal map with a sphere but not with a cube. With a normal map bitmap, it works fine on both.
Not sure but maybe it'll help you.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
Hi guys, thanks for the suggestions.
Ultimately combining the two maps together was the fix for this, I couldn't get both normals and displacement working together properly. I tried making everything octane imagemap textures, no c4d shaders, everything 16 bit, etc to no avail.
It would be great if the two could co exist as it would speed things up. I've attached a still of the issue I was having for reference. I've graded the one on the right and put rough wireframe over so you can see where the breaks in the normal map are occurring.
there maybe some problems on displacement and bump/normal maps. you can check standalone topics for this kind of issues
Thanks for letting me know.
Does this also include displacement and shadows? I'm encountering a strange issue where I have an object sitting on a plane, I am displacing the plane around the object but not directly under it (ie displacement is black around the object so in theory no geometry movement) but it's lifting the mesh up even where it's black. I compensate by using the shift parameter but the shadow moves with the shift, so in other words the shadow looks like it's being cast by an object slightly lower than my actual visible one.
Weird.
Weird.
Well that job has finished up now, it was not too painful all up. The displacement + normals bug remained throughout however combining the maps into a single displacement map worked. A bit of a pain in the ass but not too bad.
The final job is at http://www.toyota.com/fuelcell/index.html, it's the intro video that plays when you hit the page. It is compressed as hell, I will post a higher quality version when it goes online.
A couple of notes - the end shot with realistic car is created by a different company (not me) using vray. The clouds and train steam are Turbulence 4D. And that's about it.
Any questions I'm happy to answer them.
